How to Web access into host devices
  • jlmallard
    • Jul 2019
    I want to be able to click on a configured host in a map and be able to Web to that device usings its own Web configuration to monitor or configure it. So, if i have a firewall interface configured, it will allow me to bring up a Web page of that device, perhaps it may use a bespoke port number, login to it and interactively use a Web browser to configure and monitor it. It seems easy enough as that is the sort of thing that I could do using HP Openview, but perhaps it is more comlicated ? Any ideas gratefully received, thanks!!
  • Atsushi
    • Aug 2013
    • 2028
    URLs can be set for map elements. Go to the map edit screen and click on the element of the target map. There should be an item called "URLs" at the bottom of the pop-up screen that appears when you click. Try setting the URL you want to access there.
    • jlmallard
      • Jul 2019
      Brilliant! Thanks very much, Atsushi! Now I feel a right fool- I never saw that option !! Too simple!!
      • jlmallard
        • Jul 2019
        If I may pick your brains again, Atushi!!!, how do I get the URL to open up in a new browser window, so that when i have used that application and I have finished with it and logout, my map is still open ? Cheers!
          • 4970
          Hold down CTRL while clicking.....
          • petert92
            • Aug 2021
            SOLVED: http://{HOST.IP}
            Hi everyone! I tried this idea but when I use it takes me to zabbixDomain/URL and I just need the URL. Any idea why? v5.2
