Hey There,
I am trying to install Zabbix Network management Tool on our ClearOS Server and this is the errors I get when installing it.
Could you possibly assist me with this installation?
[root@griffin src]# yum --enablerepo=clearos-epel install zabbix-server-mysql zabbix-web-mysql zabbix-agent Loaded plugins: clearcenter-marketplace, fastestmirror Setting up Install Process ClearCenter Marketplace: fetching repositories...
Loading mirror speeds from cached hostfile
had to remove links
Dependencies
--> Running transaction check
---> Package zabbix-agent.x86_64 0:1.8.22-1.el6 will be installed
--> Processing Dependency: zabbix = 1.8.22-1.el6 for package:
--> zabbix-agent-1.8.22-1.el6.x86_64
---> Package zabbix-server-mysql.x86_64 0:1.8.22-1.el6 will be installed
--> Processing Dependency: zabbix-server = 1.8.22-1.el6 for package:
--> zabbix-server-mysql-1.8.22-1.el6.x86_64
--> Processing Dependency: libodbc.so.2()(64bit) for package:
--> Processing Dependency: libiksemel.so.3()(64bit) for package:
--> Processing Dependency: libOpenIPMIposix.so.0()(64bit) for package:
--> Processing Dependency: libOpenIPMI.so.0()(64bit) for package:
---> Package zabbix-web-mysql.noarch 0:1.8.22-1.el6 will be installed
--> Processing Dependency: zabbix-web = 1.8.22-1.el6 for package:
--> zabbix-web-mysql-1.8.22-1.el6.noarch
---> Package iksemel.x86_64 0:1.4-2.el6 will be installed Package
---> zabbix.x86_64 0:1.8.22-1.el6 will be installed Package
---> zabbix-server.x86_64 0:1.8.22-1.el6 will be installed
--> Processing Dependency: fping for package:
--> zabbix-server-1.8.22-1.el6.x86_64
---> Package zabbix-web.noarch 0:1.8.22-1.el6 will be installed
--> Processing Dependency: php-bcmath for package:
--> zabbix-web-1.8.22-1.el6.noarch Running transaction check
---> Package fping.x86_64 0:2.4b2-10.el6 will be installed Package
---> php-bcmath.x86_64 0:5.3.3-40.el6_6 will be installed
--> Processing Dependency: php-common(x86-64) = 5.3.3-40.el6_6 for
--> package: php-bcmath-5.3.3-40.el6_6.x86_64
--> Finished Dependency Resolution
Error: Package: zabbix-server-mysql-1.8.22-1.el6.x86_64 (clearos-epel)
Requires: libodbc.so.2()(64bit)
Requires: libOpenIPMIposix.so.0()(64bit)
Error: Package: php-bcmath-5.3.3-40.el6_6.x86_64 (clearos)
Requires: php-common(x86-64) = 5.3.3-40.el6_6
Installed: php-common-5.3.3-46.el6_6.x86_64 (@clearos-core)
php-common(x86-64) = 5.3.3-46.el6_6
Available: php-common-5.3.3-40.el6_6.x86_64 (clearos)
Requires: libOpenIPMI.so.0()(64bit) You could try using --skip-broken to work around the problem You could try running: rpm -Va --nofiles --nodigest =============================================
had to remove links
Dependencies
