Zabbix Server/Proxy docker poller process more then 75% busy - false alert
  • Amiram
    • Feb 2021
    • 59
    Hey,
    I have an environment with 1 server and 10 proxies running inside the following containers:
    • Server -
      HTML Code:
      https://hub.docker.com/r/zabbix/zabbix-server-mysql
    • Proxy -
      HTML Code:
      https://hub.docker.com/r/zabbix/zabbix-proxy-mysql
    Version: ubuntu-5.4-latest
    Since I installed the environment I'm getting an alert that the poller process is busy
    Zabbix poller processes more than 75% busy
    and it stand at 100% all the time.
    No agents are assign for monitor just the proxies themselfs.
    I have look at the process itself
    ps -ef | grep zabbix_server | grep proller
    and I can see that the process is doing NOTHING.
    Any ideas?
    ** The server and proxies are running inside a container **
  • Amiram
    • Feb 2021
    • 59
    Anyone any idea?
    • Atsushi
      • Aug 2013
      • 2028
      Where did you execute the ps command? Did you execute on the Zabbix server container and see the processes inside the container?
      • Amiram
        • Feb 2021
        • 59
        Yes,
        I'm getting the same results inside and outside the container due to the fact that I'm running the container with pid=host.
        • Amiram
          • Feb 2021
          • 59
          As posted here:
          HTML Code:
          https://www.zabbix.com/forum/zabbix-help/381417-monitor-active-proxy-last-seen?p=382152#post382152
          It seems that it not a good idea to monitor the zabbix proxy processes using the server it self.
          I have changed it and it seems that the problem resolved - at least at this end.
          I'm still having an issue at the Server itself that showing 100% data poller utilization.
          • Amiram
            Amiram commented
            The issue with the server resolved once the proxy started to monitor themselves.
