Zabbix 2.4 agent rpms for RHEL8
  • logix88
    • May 2015
    We have a Zabbix 2.4 server that isn't currently in line to be upgraded however we also have RHEL8 OS being deployed.
    I can see a zabbix-agent rpm for el8 but sender still shows up as el7
    rpm -qa |grep zabbix
    zabbix-release-2.4-1.el7.noarch
    zabbix-agent-2.4.8-2.el8.x86_64
    zabbix-sender-2.4.8-1.el7.x86_64
    Is this fine to use in RHEL8? Any suggestions i.e. I don't suppose we can use Zabbix Agent 3.x with Zabbix Server 2.4?
  • Semiadmin
    • Oct 2014
    • 1626
    Hi. logix88.
    You may use agents v3.* with Zabbix Server v2.4 and enjoy new agent keys.
    But I didn't find any 3.2 or 3.4 agent and sender rpm for RHEL8 at the Zabbix repo.
    Anyway, you may use agent and sender v3.0.
    • logix88
      • May 2015
      Originally posted by Semiadmin
      Hi. logix88.
      Thanks, will test it out.. though I suppose this is can't be officially supported, considering 2.4 is not supported at all anyway.
