Ensure Free Disk Space Triggers Are Working On Linux VM... Help With Templates Needed
  • TitanRob16
    • Mar 2019
    I first confess I don't have a great deal of experience with Zabbix configuration, so apologies in advance if I've misunderstood anything.
    I've installed the Zabbix agent on a Linux VM, and I want to monitor the free disk space available so that I can clear the space/increase the space before any major issues occur.
    Under Configuration - Hosts - My Linux VM - Triggers, there are 15 triggers assigned, none of which are related to free disk space. The majority of these are inherited from the Template OS Linux.
    Under Discovery Rules - mounted filesystem discovery, I can see what I need under Trigger Prototypes. So when I return to the host page and click on Triggers - Create Trigger - Add Expression - and go to select an Item, the prototypes I want aren't listed under Templates - OS Linux. Why?
    If I copy the expression from the Prototype and use that in the creation of a new trigger, I get: Trigger "Free disk space is less than 10% on volume {#FSNAME}" already exists on "Template OS Linux".
    If I change the name of the trigger, I get: Incorrect item key "vfs.fs.size[{#FSNAME},pfree]" provided for trigger expression on "Template OS Linux".
    So what am I doing wrong here? It's driving me mad... it's not intuitive at all.
    Any help would be greatly appreciated!
  • TitanRob16
    • Mar 2019
    Originally posted by cyber
    You should not need to create anything there manually. That discovery rule should create all needed items and triggers based on those prototypes. I think it has default delay of 1h... so wait one hour if you have "active" template. Or press "check now" for discovery, if you have passive template..
    AH! Thank you! I can see the triggers have appeared now
