zabbix 5.4.5 rpmbuild from sources on amazon linux 2 amzn2
  • bunkzilla
    • Feb 2017
    zabbix 5.4.5
    I've been able to get working rpms for everything except zabbix-web-service and zabbix-agent2 ( go 1.16 not available yet )
    time rpmbuild -ba ~/rpmbuild/SPECS/zabbix.spec | tee build_out.txt
    Executing(%prep): /bin/sh -e /var/tmp/rpm-tmp.0fNrIG
    + umask 022
    + cd /root/rpmbuild/BUILD
    + rm -rf zabbix-5.4.5
    + /usr/bin/gzip -dc /root/rpmbuild/SOURCES/zabbix-5.4.5.tar.gz
    + /usr/bin/tar -xf -
    + STATUS=0
    + '[' 0 -ne 0 ']'
    + cd zabbix-5.4.5
    + /usr/bin/chmod -Rf a+rX,u+w,g-w,o-w .
    + echo 'Patch #3 (conf.patch):'
    + /usr/bin/cat /root/rpmbuild/SOURCES/conf.patch
    + /usr/bin/patch -p1 --fuzz=0
    patching file conf/zabbix_agentd.conf
    patching file conf/zabbix_proxy.conf
    patching file conf/zabbix_server.conf
    Hunk #6 succeeded at 544 (offset -2 lines).
    Hunk #7 succeeded at 553 (offset -2 lines).
    patching file src/go/conf/zabbix_agent2.conf
    patching file src/go/conf/zabbix_web_service.conf
    + exit 0
    Executing(%build): /bin/sh -e /var/tmp/rpm-tmp.NO3bQq
    + umask 022
    + cd zabbix-5.4.5
    + build_conf_common='
    --enable-dependency-tracking
    --sysconfdir=/etc/zabbix
    --libdir=/usr/lib64/zabbix
    --enable-ipv6
    --with-net-snmp
    --with-ldap
    --with-libcurl
    --with-openipmi
    --with-unixodbc
    --with-ssh2
    --with-libxml2
    --with-libevent
    --with-libpcre
    --with-openssl
    + build_conf_3='
    --enable-webservice
    + '[' -n '' ']'
    + '[' -n '' ']'
    + '[' -n '
    --enable-webservice
    + CFLAGS='-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic'
    + export CFLAGS
    + CXXFLAGS='-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic'
    + export CXXFLAGS
    + FFLAGS='-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -I/usr/lib64/gfortran/modules'
    + export FFLAGS
    + FCFLAGS='-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -I/usr/lib64/gfortran/modules'
    + export FCFLAGS
    + LDFLAGS='-Wl,-z,relro '
    + export LDFLAGS
    + '[' 1 == 1 ']'
    + '[' x86_64 == ppc64le ']'
    ++ find . -name config.guess -o -name config.sub
    + for i in '$(find . -name config.guess -o -name config.sub)'
    ++ basename ./config.guess
    + '[' -f /usr/lib/rpm/redhat/config.guess ']'
    + /usr/bin/rm -f ./config.guess
    + /usr/bin/cp -fv /usr/lib/rpm/redhat/config.guess ./config.guess
    '/usr/lib/rpm/redhat/config.guess' -> './config.guess'
    ++ basename ./config.sub
    + '[' -f /usr/lib/rpm/redhat/config.sub ']'
    + /usr/bin/rm -f ./config.sub
    + /usr/bin/cp -fv /usr/lib/rpm/redhat/config.sub ./config.sub
    '/usr/lib/rpm/redhat/config.sub' -> './config.sub'
    + ./configure --build=x86_64-redhat-linux-gnu --host=x86_64-redhat-linux-gnu --program-prefix= --disable-dependency-tracking --prefix=/usr --exec-prefix=/usr --bindir=/usr/bin --sbindir=/usr/sbin --sysconfdir=/etc --datadir=/usr/share --includedir=/usr/include --libdir=/usr/lib64 --libexecdir=/usr/libexec --localstatedir=/var --sharedstatedir=/var/lib --mandir=/usr/share/man --infodir=/usr/share/info --enable-dependency-tracking --sysconfdir=/etc/zabbix --libdir=/usr/lib64/zabbix --enable-ipv6 --with-net-snmp --with-ldap --with-libcurl --with-openipmi --with-unixodbc --with-ssh2 --with-libxml2 --with-libevent --with-libpcre --with-openssl --enable-webservice
    checking for a BSD-compatible install... /usr/bin/install -c
    checking whether build environment is sane... yes
    checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
    checking for gawk... gawk
    checking whether make sets $(MAKE)... yes
    checking whether make supports nested variables... yes
    configure: Configuring Zabbix 5.4.5
    checking whether make sets $(MAKE)... (cached) yes
    checking build system type... x86_64-redhat-linux-gnu
    checking host system type... x86_64-redhat-linux-gnu
    checking for x86_64-redhat-linux-gnu-cc... no
    checking for x86_64-redhat-linux-gnu-c99... no
    checking for x86_64-redhat-linux-gnu-gcc... no
    checking for x86_64-redhat-linux-gnu-clang... no
    checking for cc... cc
    checking whether the C compiler works... yes
    checking for C compiler default output file name... a.out
    checking for suffix of executables...
    checking whether we are cross compiling... no
    checking for suffix of object files... o
    checking whether we are using the GNU C compiler... yes
    checking whether cc accepts -g... yes
    checking for cc option to accept ISO C89... none needed
    checking whether cc understands -c and -o together... yes
    checking whether make supports the include directive... yes (GNU style)
    checking dependency style of cc... gcc3
    checking how to run the C preprocessor... cc -E
    checking for grep that handles long lines and -e... /usr/bin/grep
    checking for egrep... /usr/bin/grep -E
    checking for ANSI C header files... yes
    checking for sys/types.h... yes
    checking for sys/stat.h... yes
    checking for stdlib.h... yes
    checking for string.h... yes
    checking for memory.h... yes
    checking for strings.h... yes
    checking for inttypes.h... yes
    checking for stdint.h... yes
    checking for unistd.h... yes
    checking stdio.h usability... yes
    checking stdio.h presence... yes
    checking for stdio.h... yes
    checking for stdlib.h... (cached) yes
    checking for string.h... (cached) yes
    checking for unistd.h... (cached) yes
    checking netdb.h usability... yes
    checking netdb.h presence... yes
    checking for netdb.h... yes
    checking signal.h usability... yes
    checking signal.h presence... yes
    checking for signal.h... yes
    checking syslog.h usability... yes
    checking syslog.h presence... yes
    checking for syslog.h... yes
    checking time.h usability... yes
    checking time.h presence... yes
    checking for time.h... yes
    checking errno.h usability... yes
    checking errno.h presence... yes
    checking for errno.h... yes
    checking for sys/types.h... (cached) yes
    checking for sys/stat.h... (cached) yes
    checking netinet/in.h usability... yes
    checking netinet/in.h presence... yes
    checking for netinet/in.h... yes
    checking math.h usability... yes
    checking math.h presence... yes
    checking for math.h... yes
    checking sys/socket.h usability... yes
    checking sys/socket.h presence... yes
    checking for sys/socket.h... yes
    checking dirent.h usability... yes
    checking dirent.h presence... yes
    checking for dirent.h... yes
    checking ctype.h usability... yes
    checking ctype.h presence... yes
    checking for ctype.h... yes
    checking mtent.h usability... no
    checking mtent.h presence... no
    checking for mtent.h... no
    checking fcntl.h usability... yes
    checking fcntl.h presence... yes
    checking for fcntl.h... yes
    checking sys/param.h usability... yes
    checking sys/param.h presence... yes
    checking for sys/param.h... yes
    checking arpa/inet.h usability... yes
    checking arpa/inet.h presence... yes
    checking for arpa/inet.h... yes
    checking sys/vfs.h usability... yes
    checking sys/vfs.h presence... yes
    checking for sys/vfs.h... yes
    checking sys/pstat.h usability... no
    checking sys/pstat.h presence... no
    checking for sys/pstat.h... no
    checking sys/sysinfo.h usability... yes
    checking sys/sysinfo.h presence... yes
    checking for sys/sysinfo.h... yes
    checking sys/statvfs.h usability... yes
    checking sys/statvfs.h presence... yes
    checking for sys/statvfs.h... yes
    checking sys/statfs.h usability... yes
    checking sys/statfs.h presence... yes
    checking for sys/statfs.h... yes
    checking for sys/socket.h... (cached) yes
    checking sys/loadavg.h usability... no
    checking sys/loadavg.h presence... no
    checking for sys/loadavg.h... no
    checking for arpa/inet.h... (cached) yes
    checking sys/vmmeter.h usability... no
    checking sys/vmmeter.h presence... no
    checking for sys/vmmeter.h... no
    checking for strings.h... (cached) yes
    checking vm/vm_param.h usability... no
    checking vm/vm_param.h presence... no
    checking for vm/vm_param.h... no
    checking sys/time.h usability... yes
    checking sys/time.h presence... yes
    checking for sys/time.h... yes
    checking kstat.h usability... no
    checking kstat.h presence... no
    checking for kstat.h... no
    checking sys/syscall.h usability... yes
    checking sys/syscall.h presence... yes
    checking for sys/syscall.h... yes
    checking sys/sysmacros.h usability... yes
    checking sys/sysmacros.h presence... yes
    checking for sys/sysmacros.h... yes
    checking for stdint.h... (cached) yes
    checking mach/host_info.h usability... no
    checking mach/host_info.h presence... no
    checking for mach/host_info.h... no
    checking mach/mach_host.h usability... no
    checking mach/mach_host.h presence... no
    checking for mach/mach_host.h... no
    checking knlist.h usability... no
    checking knlist.h presence... no
    checking for knlist.h... no
    checking pwd.h usability... yes
    checking pwd.h presence... yes
    checking for pwd.h... yes
    checking sys/var.h usability... no
    checking sys/var.h presence... no
    checking for sys/var.h... no
    checking arpa/nameser.h usability... yes
    checking arpa/nameser.h presence... yes
    checking for arpa/nameser.h... yes
    checking assert.h usability... yes
    checking assert.h presence... yes
    checking for assert.h... yes
    checking sys/dkstat.h usability... no
    checking sys/dkstat.h presence... no
    checking for sys/dkstat.h... no
    checking sys/disk.h usability... no
    checking sys/disk.h presence... no
    checking for sys/disk.h... no
    checking sys/sched.h usability... no
    checking sys/sched.h presence... no
    checking for sys/sched.h... no
    checking zone.h usability... no
    checking zone.h presence... no
    checking for zone.h... no
    checking nlist.h usability... yes
    checking nlist.h presence... yes
    checking for nlist.h... yes
    checking kvm.h usability... no
    checking kvm.h presence... no
    checking for kvm.h... no
    checking linux/kernel.h usability... yes
    checking linux/kernel.h presence... yes
    checking for linux/kernel.h... yes
    checking procinfo.h usability... no
    checking procinfo.h presence... no
    checking for procinfo.h... no
    checking sys/dk.h usability... no
    checking sys/dk.h presence... no
    checking for sys/dk.h... no
    checking sys/resource.h usability... yes
    checking sys/resource.h presence... yes
    checking for sys/resource.h... yes
    checking pthread.h usability... yes
    checking pthread.h presence... yes
    checking for pthread.h... yes
    checking windows.h usability... no
    checking windows.h presence... no
    checking for windows.h... no
    checking process.h usability... no
    checking process.h presence... no
    checking for process.h... no
    checking conio.h usability... no
    checking conio.h presence... no
    checking for conio.h... no
    checking sys/wait.h usability... yes
    checking sys/wait.h presence... yes
    checking for sys/wait.h... yes
    checking stdarg.h usability... yes
    checking stdarg.h presence... yes
    checking for stdarg.h... yes
    checking winsock2.h usability... no
    checking winsock2.h presence... no
    checking for winsock2.h... no
    checking pdh.h usability... no
    checking pdh.h presence... no
    checking for pdh.h... no
    checking psapi.h usability... no
    checking psapi.h presence... no
    checking for psapi.h... no
    checking sys/sem.h usability... yes
    checking sys/sem.h presence... yes
    checking for sys/sem.h... yes
    checking sys/ipc.h usability... yes
    checking sys/ipc.h presence... yes
    checking for sys/ipc.h... yes
    checking sys/shm.h usability... yes
    checking sys/shm.h presence... yes
    checking for sys/shm.h... yes
    checking Winldap.h usability... no
    checking Winldap.h presence... no
    checking for Winldap.h... no
    checking Winber.h usability... no
    checking Winber.h presence... no
    checking for Winber.h... no
    checking lber.h usability... yes
    checking lber.h presence... yes
    checking for lber.h... yes
    checking ws2tcpip.h usability... no
    checking ws2tcpip.h presence... no
    checking for ws2tcpip.h... no
    checking for inttypes.h... (cached) yes
    checking sys/file.h usability... yes
    checking sys/file.h presence... yes
    checking for sys/file.h... yes
    checking grp.h usability... yes
    checking grp.h presence... yes
    checking for grp.h... yes
    checking execinfo.h usability... yes
    checking execinfo.h presence... yes
    checking for execinfo.h... yes
    checking sys/systemcfg.h usability... no
    checking sys/systemcfg.h presence... no
    checking for sys/systemcfg.h... no
    checking sys/mnttab.h usability... no
    checking sys/mnttab.h presence... no
    checking for sys/mnttab.h... no
    checking mntent.h usability... yes
    checking mntent.h presence... yes
    checking for mntent.h... yes
    checking sys/times.h usability... yes
    checking sys/times.h presence... yes
    checking for sys/times.h... yes
    checking dlfcn.h usability... yes
    checking dlfcn.h presence... yes
    checking for dlfcn.h... yes
    checking sys/utsname.h usability... yes
    checking sys/utsname.h presence... yes
    checking for sys/utsname.h... yes
    checking sys/un.h usability... yes
    checking sys/un.h presence... yes
    checking for sys/un.h... yes
    checking sys/protosw.h usability... no
    checking sys/protosw.h presence... no
    checking for sys/protosw.h... no
    checking stddef.h usability... yes
    checking stddef.h presence... yes
    checking for stddef.h... yes
    checking limits.h usability... yes
    checking limits.h presence... yes
    checking for limits.h... yes
    checking float.h usability... yes
    checking float.h presence... yes
    checking for float.h... yes
    checking for resolv.h... yes
    checking for net/if.h... yes
    checking for net/if_mib.h... no
    checking whether compiler supports -Werror=cpp... yes
    checking for sys/mount.h... yes
    checking for sys/proc.h... no
    checking for sys/sysctl.h... yes
    checking for sys/user.h... yes
    checking for sys/swap.h... yes
    checking for sys/ucontext.h... yes
    checking for devstat.h... no
    checking for linux/netlink.h... yes
    checking linux/inet_diag.h usability... yes
    checking linux/inet_diag.h presence... yes
    checking for linux/inet_diag.h... yes
    checking for libperfstat.h... no
    checking for library containing socket... none required
    checking for library containing kstat_open... no
    checking for library containing gethostbyname... none required
    checking for library containing clock_gettime... none required
    checking for library containing dlopen... -ldl
    checking for library containing perfstat_memory_total... no
    checking for library containing devstat_getdevs... no
    checking for library containing getdevs... no
    checking for library containing backtrace_symbols... none required
    checking for main in -lm... yes
    checking for main in -lkvm... no
    checking for DNS lookup functions... yes
    checking for special C compiler options needed for large files... no
    checking for _FILE_OFFSET_BITS value needed for large files... no
    checking for an ANSI C-conforming const... yes
    checking for pid_t... yes
    checking for socklen_t... yes
    checking for actual socklen_t parameter type in socket functions... socklen_t
    checking for integer field name in union sigval of struct siginfo_t... sival_int
    checking for res_ninit... yes
    checking for res_ndestroy... no
    checking for _res._u._ext.nsaddrs... yes
    checking for _res._u._ext.ext... no
    checking for _res._ext.ext.nsaddrs... no
    checking for struct sockaddr_in6.sin6_len... no
    checking for union semun... no
    checking for struct swaptable in sys/swap.h... no
    checking for struct sensordev in sys/sensors.h... no
    checking for struct statvfs64 in sys/statvfs.h... no
    checking for struct statfs64 in sys/statfs.h... no
    checking for field ss_family in struct sockaddr_storage... yes
    checking for field mem_unit in struct sysinfo... yes
    checking for field freeswap in struct sysinfo... yes
    checking for field totalswap in struct sysinfo... yes
    checking for field totalram in struct sysinfo... yes
    checking for field sharedram in struct sysinfo... yes
    checking for field bufferram in struct sysinfo... yes
    checking for field freeram in struct sysinfo... yes
    checking for field uptime in struct sysinfo... yes
    checking for field procs in struct sysinfo... yes
    checking for field tm_gmtoff in struct tm... yes
    checking for linker options --start-group/--end-group... yes
    checking for '__thread' compiler support... yes
    checking for field updates in struct vminfo_t... no
    checking for function sysconf() in unistd.h... yes
    checking for function initgroups()... yes
    checking for functions seteuid() and setegid()... yes
    checking for function setproctitle()... no
    checking for function sysctlbyname()... no
    checking for function sysctl (KERN_BOOTTIME)... no
    checking for function sysctl (HW_NCPU)... no
    checking for function sysctl (KERN_MAXFILES)... no
    checking for function sysctl (KERN_MAXPROC)... no
    checking for function sysctl (KERN_CPTIME,KERN_CPTIME2)... no
    checking for function clock_gettime in time.h... yes
    checking for macro __va_copy() in stdarg.h... yes
    checking for macro __VA_ARGS__... yes
    checking return type of signal handlers... void
    checking for getloadavg... yes
    checking for hstrerror... yes
    checking for getenv... yes
    checking for putenv... yes
    checking for setenv... yes
    checking for tzset... yes
    checking for unsetenv... yes
    checking for sigqueue... yes
    checking for round... yes
    checking for /proc filesystem... yes
    checking for file /proc/stat... yes
    checking for file /proc/cpuinfo... yes
    checking for file /proc/0/psinfo... no
    checking for file /proc/loadavg... yes
    checking for file /proc/net/dev... yes
    checking for long long format... no
    checking for -rdynamic linking option... yes
    checking for libperfstat 5.2.0.40 fileset... no
    checking for libperfstat 5.3.0.60 fileset... no
    checking for architecture... linux (linux-gnu)
    checking for the linux kernel version... unknown family (5.10.47-linuxkit)
    checking size of void *... 8
    checking for OpenSSL support... yes
    checking if OpenSSL supports PSK... yes
    checking for go... go
    checking for LDAP support of ldap.h... yes
    checking for gawk... (cached) gawk
    checking for curl-config... /usr/bin/curl-config
    checking for the version of libcurl... 7.76.1
    checking for libcurl >= version 7.13.1... yes
    checking for main in -lcurl... yes
    checking whether libcurl is usable... yes
    checking for curl_free... yes
    checking for curl_easy_escape... yes
    checking iconv.h usability... yes
    checking iconv.h presence... yes
    checking for iconv.h... yes
    checking for ICONV support... yes
    checking for mkdir -p candidate... ok (/usr/bin/mkdir -p)
    checking that generated files are newer than configure... done
    configure: creating ./config.status
    config.status: creating Makefile
    config.status: creating database/Makefile
    config.status: creating database/mysql/Makefile
    config.status: creating database/oracle/Makefile
    config.status: creating database/postgresql/Makefile
    config.status: creating database/sqlite3/Makefile
    config.status: creating misc/Makefile
    config.status: creating src/Makefile
    config.status: creating src/go/Makefile
    config.status: creating src/libs/Makefile
    config.status: creating src/libs/zbxlog/Makefile
    config.status: creating src/libs/zbxalgo/Makefile
    config.status: creating src/libs/zbxmemory/Makefile
    config.status: creating src/libs/zbxcrypto/Makefile
    config.status: creating src/libs/zbxconf/Makefile
    config.status: creating src/libs/zbxdbcache/Makefile
    config.status: creating src/libs/zbxdbhigh/Makefile
    config.status: creating src/libs/zbxmedia/Makefile
    config.status: creating src/libs/zbxsysinfo/Makefile
    config.status: creating src/libs/zbxcommon/Makefile
    config.status: creating src/libs/zbxsysinfo/agent/Makefile
    config.status: creating src/libs/zbxsysinfo/common/Makefile
    config.status: creating src/libs/zbxsysinfo/simple/Makefile
    config.status: creating src/libs/zbxsysinfo/linux/Makefile
    config.status: creating src/libs/zbxsysinfo/aix/Makefile
    config.status: creating src/libs/zbxsysinfo/freebsd/Makefile
    config.status: creating src/libs/zbxsysinfo/hpux/Makefile
    config.status: creating src/libs/zbxsysinfo/openbsd/Makefile
    config.status: creating src/libs/zbxsysinfo/osx/Makefile
    config.status: creating src/libs/zbxsysinfo/solaris/Makefile
    config.status: creating src/libs/zbxsysinfo/osf/Makefile
    config.status: creating src/libs/zbxsysinfo/netbsd/Makefile
    config.status: creating src/libs/zbxsysinfo/unknown/Makefile
    config.status: creating src/libs/zbxnix/Makefile
    config.status: creating src/libs/zbxsys/Makefile
    config.status: creating src/libs/zbxcomms/Makefile
    config.status: creating src/libs/zbxcommshigh/Makefile
    config.status: creating src/libs/zbxdb/Makefile
    config.status: creating src/libs/zbxdbupgrade/Makefile
    config.status: creating src/libs/zbxjson/Makefile
    config.status: creating src/libs/zbxhttp/Makefile
    config.status: creating src/libs/zbxserver/Makefile
    config.status: creating src/libs/zbxicmpping/Makefile
    config.status: creating src/libs/zbxeval/Makefile
    config.status: creating src/libs/zbxexec/Makefile
    config.status: creating src/libs/zbxself/Makefile
    config.status: creating src/libs/zbxmodules/Makefile
    config.status: creating src/libs/zbxregexp/Makefile
    config.status: creating src/libs/zbxtasks/Makefile
    config.status: creating src/libs/zbxipcservice/Makefile
    config.status: creating src/libs/zbxhistory/Makefile
    config.status: creating src/libs/zbxcompress/Makefile
    config.status: creating src/libs/zbxembed/Makefile
    config.status: creating src/libs/zbxprometheus/Makefile
    config.status: creating src/libs/zbxvault/Makefile
    config.status: creating src/libs/zbxdiag/Makefile
    config.status: creating src/libs/zbxtrends/Makefile
    config.status: creating src/libs/zbxavailability/Makefile
    config.status: creating src/libs/zbxxml/Makefile
    config.status: creating src/zabbix_agent/Makefile
    config.status: creating src/zabbix_agent/logfiles/Makefile
    config.status: creating src/zabbix_get/Makefile
    config.status: creating src/zabbix_js/Makefile
    config.status: creating src/zabbix_sender/Makefile
    config.status: creating src/zabbix_server/Makefile
    config.status: creating src/zabbix_server/alerter/Makefile
    config.status: creating src/zabbix_server/dbsyncer/Makefile
    config.status: creating src/zabbix_server/dbconfig/Makefile
    config.status: creating src/zabbix_server/discoverer/Makefile
    config.status: creating src/zabbix_server/housekeeper/Makefile
    config.status: creating src/zabbix_server/httppoller/Makefile
    config.status: creating src/zabbix_server/pinger/Makefile
    config.status: creating src/zabbix_server/poller/Makefile
    config.status: creating src/zabbix_server/snmptrapper/Makefile
    config.status: creating src/zabbix_server/timer/Makefile
    config.status: creating src/zabbix_server/trapper/Makefile
    config.status: creating src/zabbix_server/escalator/Makefile
    config.status: creating src/zabbix_server/proxypoller/Makefile
    config.status: creating src/zabbix_server/selfmon/Makefile
    config.status: creating src/zabbix_server/vmware/Makefile
    config.status: creating src/zabbix_server/taskmanager/Makefile
    config.status: creating src/zabbix_server/ipmi/Makefile
    config.status: creating src/zabbix_server/odbc/Makefile
    config.status: creating src/zabbix_server/scripts/Makefile
    config.status: creating src/zabbix_server/preprocessor/Makefile
    config.status: creating src/zabbix_server/availability/Makefile
    config.status: creating src/zabbix_server/lld/Makefile
    config.status: creating src/zabbix_server/reporter/Makefile
    config.status: creating src/zabbix_proxy/Makefile
    config.status: creating src/zabbix_proxy/heart/Makefile
    config.status: creating src/zabbix_proxy/housekeeper/Makefile
    config.status: creating src/zabbix_proxy/proxyconfig/Makefile
    config.status: creating src/zabbix_proxy/datasender/Makefile
    config.status: creating src/zabbix_proxy/taskmanager/Makefile
    config.status: creating src/zabbix_java/Makefile
    config.status: creating man/Makefile
    config.status: creating include/config.h
    config.status: executing depfiles commands
    Configuration:
    Detected OS: linux-gnu
    Install path: /usr
    Compilation arch: linux
    Compiler: cc
    Compiler flags: -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic
    Library-specific flags:
    TLS: -I/usr/include
    LDAP: -I/usr/include
    Enable server: no
    Enable proxy: no
    Enable agent: no
    Enable agent 2: no
    Enable web service: yes
    Enable Java gateway: no
    LDAP support: yes
    IPv6 support: yes
    * Now run 'make install' *
    * Thank you for using Zabbix! *
    * <http://www.zabbix.com> *
    + make
    Making all in src
    make[1]: Entering directory `/root/rpmbuild/BUILD/zabbix-5.4.5/src'
    Making all in go
    make[2]: Entering directory `/root/rpmbuild/BUILD/zabbix-5.4.5/src/go'
    go build -ldflags="-X 'zabbix.com/pkg/version.compileDate=`date +"%b %_d %Y"`' -X zabbix.com/pkg/version.compileTime=`date +%H:%M:%S` -X zabbix.com/pkg/version.compileOs=`go env GOOS` -X zabbix.com/pkg/version.compileArch=`go env GOARCH` -X main.applicationName=zabbix_web_service" -o bin zabbix.com/cmd/zabbix_web_service
    make[2]: Leaving directory `/root/rpmbuild/BUILD/zabbix-5.4.5/src/go'
    make[2]: Entering directory `/root/rpmbuild/BUILD/zabbix-5.4.5/src'
    make[2]: Nothing to be done for `all-am'.
    make[2]: Leaving directory `/root/rpmbuild/BUILD/zabbix-5.4.5/src'
    make[1]: Leaving directory `/root/rpmbuild/BUILD/zabbix-5.4.5/src'
    Making all in database
    make[1]: Entering directory `/root/rpmbuild/BUILD/zabbix-5.4.5/database'
    Making all in mysql
    make[2]: Entering directory `/root/rpmbuild/BUILD/zabbix-5.4.5/database/mysql'
    make[2]: Nothing to be done for `all'.
    make[2]: Leaving directory `/root/rpmbuild/BUILD/zabbix-5.4.5/database/mysql'
    Making all in oracle
    make[2]: Entering directory `/root/rpmbuild/BUILD/zabbix-5.4.5/database/oracle'
    make[2]: Leaving directory `/root/rpmbuild/BUILD/zabbix-5.4.5/database/oracle'
    Making all in postgresql
    make[2]: Entering directory `/root/rpmbuild/BUILD/zabbix-5.4.5/database/postgresql'
    make[2]: Leaving directory `/root/rpmbuild/BUILD/zabbix-5.4.5/database/postgresql'
    Making all in sqlite3
    make[2]: Entering directory `/root/rpmbuild/BUILD/zabbix-5.4.5/database/sqlite3'
    make[2]: Leaving directory `/root/rpmbuild/BUILD/zabbix-5.4.5/database/sqlite3'
    make[2]: Entering directory `/root/rpmbuild/BUILD/zabbix-5.4.5/database'
    make[2]: Leaving directory `/root/rpmbuild/BUILD/zabbix-5.4.5/database'
    make[1]: Leaving directory `/root/rpmbuild/BUILD/zabbix-5.4.5/database'
    Making all in man
    make[1]: Entering directory `/root/rpmbuild/BUILD/zabbix-5.4.5/man'
    make[1]: Nothing to be done for `all'.
    make[1]: Leaving directory `/root/rpmbuild/BUILD/zabbix-5.4.5/man'
    Making all in misc
    make[1]: Entering directory `/root/rpmbuild/BUILD/zabbix-5.4.5/misc'
    make[1]: Leaving directory `/root/rpmbuild/BUILD/zabbix-5.4.5/misc'
    make[1]: Entering directory `/root/rpmbuild/BUILD/zabbix-5.4.5'
    make[1]: Nothing to be done for `all-am'.
    make[1]: Leaving directory `/root/rpmbuild/BUILD/zabbix-5.4.5'
    + exit 0
    Executing(%install): /bin/sh -e /var/tmp/rpm-tmp.88mYAL
    + umask 022
    + '[' /root/rpmbuild/BUILDROOT/zabbix-5.4.5-1.amzn2.x86_64 '!=' / ']'
    + rm -rf /root/rpmbuild/BUILDROOT/zabbix-5.4.5-1.amzn2.x86_64
    ++ dirname /root/rpmbuild/BUILDROOT/zabbix-5.4.5-1.amzn2.x86_64
    + mkdir -p /root/rpmbuild/BUILDROOT
    + mkdir /root/rpmbuild/BUILDROOT/zabbix-5.4.5-1.amzn2.x86_64
    + cd zabbix-5.4.5
    + mkdir -p /root/rpmbuild/BUILDROOT/zabbix-5.4.5-1.amzn2.x86_64/var/log/zabbix
    + mkdir -p /root/rpmbuild/BUILDROOT/zabbix-5.4.5-1.amzn2.x86_64/var/run/zabbix
    + mkdir -p /root/rpmbuild/BUILDROOT/zabbix-5.4.5-1.amzn2.x86_64/etc/logrotate.d
    + mkdir -p /root/rpmbuild/BUILDROOT/zabbix-5.4.5-1.amzn2.x86_64/etc/zabbix
    + mkdir -p /root/rpmbuild/BUILDROOT/zabbix-5.4.5-1.amzn2.x86_64/usr/share
    + mkdir -p /root/rpmbuild/BUILDROOT/zabbix-5.4.5-1.amzn2.x86_64/usr/share/man/man8
    + make DESTDIR=/root/rpmbuild/BUILDROOT/zabbix-5.4.5-1.amzn2.x86_64 install
    Making install in src
    Making install in go
    make[3]: Entering directory `/root/rpmbuild/BUILD/zabbix-5.4.5/src/go'
    /usr/bin/mkdir -p '/root/rpmbuild/BUILDROOT/zabbix-5.4.5-1.amzn2.x86_64/etc/zabbix'
    /usr/bin/install -c -m 644 conf/zabbix_web_service.conf '/root/rpmbuild/BUILDROOT/zabbix-5.4.5-1.amzn2.x86_64/etc/zabbix'
    GOBIN=/usr/sbin go install -ldflags="-X 'zabbix.com/pkg/version.compileDate=`date +"%b %_d %Y"`' -X zabbix.com/pkg/version.compileTime=`date +%H:%M:%S` -X zabbix.com/pkg/version.compileOs=`go env GOOS` -X zabbix.com/pkg/version.compileArch=`go env GOARCH` -X main.applicationName=zabbix_web_service" zabbix.com/cmd/zabbix_web_service
    make[3]: Nothing to be done for `install-data-am'.
    make[3]: Leaving directory `/root/rpmbuild/BUILD/zabbix-5.4.5/src/go'
    make[3]: Entering directory `/root/rpmbuild/BUILD/zabbix-5.4.5/src'
    make[3]: Nothing to be done for `install-exec-am'.
    make[3]: Leaving directory `/root/rpmbuild/BUILD/zabbix-5.4.5/src'
    Making install in database
    Making install in mysql
    make[3]: Entering directory `/root/rpmbuild/BUILD/zabbix-5.4.5/database/mysql'
    make[3]: Leaving directory `/root/rpmbuild/BUILD/zabbix-5.4.5/database/mysql'
    Making install in oracle
    make[3]: Entering directory `/root/rpmbuild/BUILD/zabbix-5.4.5/database/oracle'
    make[3]: Leaving directory `/root/rpmbuild/BUILD/zabbix-5.4.5/database/oracle'
    Making install in postgresql
    make[3]: Entering directory `/root/rpmbuild/BUILD/zabbix-5.4.5/database/postgresql'
    make[3]: Leaving directory `/root/rpmbuild/BUILD/zabbix-5.4.5/database/postgresql'
    Making install in sqlite3
    make[3]: Entering directory `/root/rpmbuild/BUILD/zabbix-5.4.5/database/sqlite3'
    make[3]: Leaving directory `/root/rpmbuild/BUILD/zabbix-5.4.5/database/sqlite3'
    make[3]: Entering directory `/root/rpmbuild/BUILD/zabbix-5.4.5/database'
    make[3]: Leaving directory `/root/rpmbuild/BUILD/zabbix-5.4.5/database'
    Making install in man
    make[2]: Entering directory `/root/rpmbuild/BUILD/zabbix-5.4.5/man'
    make[2]: Nothing to be done for `install-exec-am'.
    /usr/bin/mkdir -p '/root/rpmbuild/BUILDROOT/zabbix-5.4.5-1.amzn2.x86_64/usr/share/man/man8'
    /usr/bin/install -c -m 644 'zabbix_web_service.man' '/root/rpmbuild/BUILDROOT/zabbix-5.4.5-1.amzn2.x86_64/usr/share/man/man8/zabbix_web_service.8'
    make[2]: Leaving directory `/root/rpmbuild/BUILD/zabbix-5.4.5/man'
    Making install in misc
    make[2]: Entering directory `/root/rpmbuild/BUILD/zabbix-5.4.5/misc'
    make[2]: Nothing to be done for `install-data-am'.
    make[2]: Leaving directory `/root/rpmbuild/BUILD/zabbix-5.4.5/misc'
    make[2]: Entering directory `/root/rpmbuild/BUILD/zabbix-5.4.5'
    make[2]: Leaving directory `/root/rpmbuild/BUILD/zabbix-5.4.5'
    + cat /root/rpmbuild/SOURCES/zabbix-logrotate.in
    + sed -e 's|COMPONENT|web-service|g'
    + cp man/zabbix_web_service.man /root/rpmbuild/BUILDROOT/zabbix-5.4.5-1.amzn2.x86_64/usr/share/man/man8/zabbix_web_service.8
    + install -Dm 0644 -p /root/rpmbuild/SOURCES/zabbix-web-service.service /root/rpmbuild/BUILDROOT/zabbix-5.4.5-1.amzn2.x86_64/usr/lib/systemd/system/zabbix-web-service.service
    + install -Dm 0644 -p /root/rpmbuild/SOURCES/zabbix-tmpfiles.conf /root/rpmbuild/BUILDROOT/zabbix-5.4.5-1.amzn2.x86_64/usr/lib/tmpfiles.d/zabbix_web_service.conf
    + /usr/lib/rpm/find-debuginfo.sh --strict-build-id -m --run-dwz --dwz-low-mem-die-limit 10000000 --dwz-max-die-limit 110000000 /root/rpmbuild/BUILD/zabbix-5.4.5
    /usr/lib/rpm/sepdebugcrcfix: Updated 0 CRC32s, 0 CRC32s did match.
    find: 'debug': No such file or directory
    + /usr/lib/rpm/check-buildroot
    + /usr/lib/rpm/redhat/brp-compress
    + /usr/lib/rpm/redhat/brp-strip-static-archive /usr/bin/strip
    + /usr/lib/rpm/brp-python-bytecompile /usr/bin/python 1
    + /usr/lib/rpm/redhat/brp-python-hardlink
    + /usr/lib/rpm/redhat/brp-java-repack-jars
    Processing files: zabbix-web-service-5.4.5-1.amzn2.x86_64
    error: File not found: /root/rpmbuild/BUILDROOT/zabbix-5.4.5-1.amzn2.x86_64/usr/sbin/zabbix_web_service
    Executing(%doc): /bin/sh -e /var/tmp/rpm-tmp.hWuLO9
    + umask 022
    + cd zabbix-5.4.5
    + DOCDIR=/root/rpmbuild/BUILDROOT/zabbix-5.4.5-1.amzn2.x86_64/usr/share/doc/zabbix-web-service-5.4.5
    + export DOCDIR
    + /usr/bin/mkdir -p /root/rpmbuild/BUILDROOT/zabbix-5.4.5-1.amzn2.x86_64/usr/share/doc/zabbix-web-service-5.4.5
    + cp -pr AUTHORS /root/rpmbuild/BUILDROOT/zabbix-5.4.5-1.amzn2.x86_64/usr/share/doc/zabbix-web-service-5.4.5
    + cp -pr ChangeLog /root/rpmbuild/BUILDROOT/zabbix-5.4.5-1.amzn2.x86_64/usr/share/doc/zabbix-web-service-5.4.5
    + cp -pr COPYING /root/rpmbuild/BUILDROOT/zabbix-5.4.5-1.amzn2.x86_64/usr/share/doc/zabbix-web-service-5.4.5
    + cp -pr NEWS /root/rpmbuild/BUILDROOT/zabbix-5.4.5-1.amzn2.x86_64/usr/share/doc/zabbix-web-service-5.4.5
    + cp -pr README /root/rpmbuild/BUILDROOT/zabbix-5.4.5-1.amzn2.x86_64/usr/share/doc/zabbix-web-service-5.4.5
    + exit 0
    RPM build errors:
    if I go and run the make command in src/go I get an zabbix_web_service executable
    bash-4.2# cd BUILD/zabbix-5.4.5/src/go/
    bash-4.2# make
    bash-4.2# pwd
    bash-4.2# ls
    Makefile Makefile.am Makefile.in bin cmd conf go.mod go.sum internal pkg plugins
    bash-4.2# bin/zabbix_web_service
    zabbix_web_service [8721]: ERROR: cannot open configuration file: open : no such file or directory
    bash-4.2#
  • tim.mooney
    • Dec 2012
    • 1436
    The RPM isn't complaining that it didn't get built.
    It's complaining that it can't find zabbix_web_service in the directory under the build root:
    Did the install target actually copy it into the expected directory?
    • bunkzilla
      bunkzilla commented
      It didn't and that's what I'm not easily figuring out. I'd imagine this should *just work*
  • bunkzilla
    • Feb 2017
    I was able to get the zabbix-web-service rpm to build by modifying the spec file as such:
    654,655d653
    < mkdir -p $RPM_BUILD_ROOT%{_sbindir}/
    < install -Dm 0644 -p $RPM_BUILD_DIR/%{name}-%{version}/src/go/bin/zabbix_web_service $RPM_BUILD_ROOT%{_sbindir}/
    • tim.mooney
      • Dec 2012
      • 1436
      My guess is it has something to do with the version of the Go language environment you have installed.
      Your original output shows that the "install" target descended into the "go" directory:
      and it installed the config file related to the web service:
      But whatever this was supposed to do:
      didn't result in the binary being copied into the buildroot. That could be something with the "install" tooling for Go. It's possible they've mainly tested it with newer versions of Go and the version you're using isn't doing what they were expecting.
      • bunkzilla
        bunkzilla commented
        Thank you, that is insightful.
        5.4.5 was the first version that required go 1.16 based on the release notes and the first version that the agent2 wouldn't compile. I've been having this problem with zabbix-web-service since 5.4.4, but had some time to try to figure it out.
