Zabbix Trapper item and Zabbix sender
  • omar.cacciotti
    • Jul 2021
    • 25
    Hello everyone!
    I'm facing with a need about managing an external message sent by another monitoring tool.
    I need to get an ALARM when a value is 1 and close it when a value is 0 and I need to get the TEXT as alarm description.
    The string (Sent by zabbix_sender from the client):
    [HYDRA] [CRITICAL: 1] [CALCIO - SIACOR-DirectDebitsQuery.getIBANValidation-Volumi-ST...] - POSTKIT
    Name = [HYDRA]
    Value = [CRITICAL: 1] (so the value is 1)
    Error = [CALCIO - SIACOR-DirectDebitsQuery.getIBANValidation-Volumi-ST...]
    So I configured this item from the guy:
    for the Host = 10.1.1.1
    Name = TEST
    Key = key.test
    Type = TEXT
    And i tested all with this command:
    #zabbix_sender -z 10.100.2.13 -s10.1.1.1 -k test.key -o "CALCIO - SIACOR-DirectDebitsQuery.getIBANValidation-Volumi-ST..." -vv
    zabbix_sender [1492946]: DEBUG: answer [{"response":"success","info":"processed: 1; failed: 0; total: 1; seconds spent: 0.000081"}]
    Response from "10.100.2.13:10051": "processed: 1; failed: 0; total: 1; seconds spent: 0.000081"
    sent: 1; skipped: 0; total: 1
    QUESTION:
    How should I approach to all this if I need to generate an alarm based on [CRITICAL: 1] and get a WARNING with [CALCIO - SIACOR-DirectDebitsQuery.getIBANValidation-Volumi-ST...] as a message?
    Thank you very much in advance!
    ​​​​​​​OC
  • splitek
    • Dec 2018
    • 101
    You need to get familiar with dependent items and value preprocessing
    In short. One item get data from sender and this data is split into two separate (dependent) items. First of this items can be numeric and will extract number and second will extract text.To extract data for both items you need to use preprocessing.
    Here is also some Zabbix blog about preprocessing: https://blog.zabbix.com/preprocessin...bix-5-0/12079/
    • omar.cacciotti
      • Jul 2021
      • 25
      Thank you for the answer,
      I already started with preprocessing but regex in Zabbix are not so clear at the moment.
      I have to check for dependent items too.
      Any other suggestion is welcome
      have a nice day!
      OC
