How to use a Trapper Item without Zabbix Sender
  • aydeisen
    • Oct 2021
    How do I send a JSON payload to a Zabbix Trapper Item without using Zabbix Sender?
    I see the documentation on how to format the sender request and I see the documentation related to the header, but I haven't found how to use the header with a JSON payload?
    My goal is to send Azure Activity Logs to Zabbix a Trapper Item using Azure Alerts.
    I don't want to setup a Script Item or equivalent that would pull the information from the Azure API, as I would then have to worry about hitting the query limit for the Azure Management APIs and being throttled by the Azure platform.
