Map labels not working
  • fly476
    • Oct 2021
    Been pulling my hair out over this one...
    Sooo i can use {HOST.HOST} and it echos the hostname. or {HOST.IP} to get the IP address. This is working as expected.
    However when i attempt to echo for example the built in zabbix Localhost Tags "system.cpu.util[,user]" Its not working.
    I have tried every rendition of quotes, no quotes, with no avail.
    Trying to use it with a host named "zab"
    should i be using "zab" in place of "HOST" below?
    {{HOST.HOST}:{system.cpu.util[,user]}
    {HOST.HOST:system.cpu.util[,user]}
    If anyone could help it would be greatly appreciated. I love this software, and this would be the icing on the cake if i coulds get it working..
    Thanks,!!
  • Hamardaban
    • May 2019
    • 2714
    {{HOST.HOST}:system.cpu.util[,user].last(0)}
    The {host:key.func(param)} macro is supported in this field, but only with avg, last, min and max trigger functions, with seconds as parameter.
    • fly476
      • Oct 2021
      Still having the issue where the label wont show data. See attached screenshot
      • fly476
        • Oct 2021
        I have read the manual over and over, watched countless tutorials... i need to get this to work...
        Tried this as well.....
        {{HOST.HOST}:system.cpu.util[,user].last(0)}Click image for larger version
        {{HOST.HOST}:agent.hostname.last(0)}
        What am I doing wrong?
        Nothing seems to work...
        Any Help would be appreciated
        • Hamardaban
          Hamardaban commented
          What version of Zabbix you are using?
      • Atsushi
        • Aug 2013
        • 2028
        I tried it with Zabbix 5.0.16 and 5.4.5, but the following description was successfully expanded and I was able to display each value. What is the detailed version of Zabbix you are using?
