Monitoring LSI raid by using storcli
  • ggs_admin
    • Oct 2021
    • 44
    Does anybody know if it's possible to monitor LSI raid via storcli via Zabbix 5.0
    I was tring to find some info on forum and found something similar (here is similar topic) but it doesn't work for Zabbix 5.0.
  • Hamardaban
    • May 2019
    • 2713
    The main idea of this article is to connect to esxi via ssh and execute the installed storcli program. How does the zabbix version affect this scenario?
    • ggs_admin
      ggs_admin commented
      thanks but I'm trying to find the way without SSH access to the monitored servers.
      I want to use "UserParameter=" for monitoring that
  • ggs_admin
    • Oct 2021
    • 44
    Actually, I'm trying to set something like follow:
    HTML Code:
    UserParameter=lsi.ctlsinfo,sudo /opt/MegaRAID/storcli/storcli64 /call show all j
    UserParameter=lsi.ldsinfo,sudo /opt/MegaRAID/storcli/storcli64 /call/vall show all j
    UserParameter=lsi.pdsinfo,sudo /opt/MegaRAID/storcli/storcli64 /call/eall/sall show all j
    UserParameter=lsi.cvsinfo,sudo /opt/MegaRAID/storcli/storcli64 /call/cv show all j
    UserParameter=lsi.bbusinfo,sudo /opt/MegaRAID/storcli/storcli64 /call/bbu show all j
    UserParameter=lsi.ctllld,sudo /opt/MegaRAID/storcli/storcli64 show all j
    UserParameter=lsi.ldlld,sudo /opt/MegaRAID/storcli/storcli64 /call/vall show all j
    UserParameter=lsi.pdlld,sudo /opt/MegaRAID/storcli/storcli64 /call/eall/sall show all j
    • ggs_admin
      • Oct 2021
      • 44
      Sure, the agent is installed, but the main the problem that these commands print too many not needed parameters.
      Ideally, I want to check only the needed things and Zabbix should trigger when something isn't working (as usually) and it should show me what exact doesn't work.
      I see that there a lot of templates for other tools like Megacli or other but not for storcli, and since I don't have permissions to change the storcli to something else I should find solution for that.
      • ggs_admin
        • Oct 2021
        • 44
        Let me show you an example of the print of the command /opt/MegaRAID/storcli/storcli64 /call show all j
        I'm not sure that it's easy to create item for that (at least for me)
        • Hamardaban
          Hamardaban commented
          Listing big is bad… But this json is good! Of course, you will have to make an effort - but everything will work well.
