problem while creating trigger Zabbix 5.4
  • Dr759123
    • Oct 2021
    • 30
    Tell me what I'm doing wrong?
  • Dr759123
    • Oct 2021
    • 30
    Thank you for such a high-quality answer.
      For 5.4 its
      function(/host/key,parameter).
      and you don't have str() function any more in 5.4.. there is find()
      I don't have 5.4 at hand but it may look like
      find(/debianZabbix/log[/var/log/auth],"like","Failed login for")=1
      There is "Add" button, use it. It helps to avoid simple mistakes in expressions, and shows you correct syntax also...
      EDIT: and you have typo in trigger name also ... it should be {HOST.NAME} not {HOSTS.NAME}
