SNMP trap to trigger - HPE stack
  • hemh
    • Apr 2020
    • 43
    Hi guys!
    I need some help to build a trigger from a SNMP trap.
    My goal is to detect an IRF topology change on a HPE switches stack.
    I made an item snmptrap[<regex>] with expression hh3cStackPortLinkStatusChange that work fine, and I receive this kind of trap:
    20:41:54 2021/10/25 ZBXTRAP 10.X.X.1
    PDU INFO:
    notificationtype TRAP
    version 1
    receivedfrom UDP: [10.X.X.1]:8514->[172.X.X.253]:162
    errorstatus 0
    messageid 0
    community mycommunity
    transactionid 15185
    errorindex 0
    requestid 449115569
    VARBINDS:
    DISMAN-EVENT-MIB::sysUpTimeInstance type=67 value=Timeticks: (68454740) 7 days, 22:09:07.40
    SNMPv2-MIB::snmpTrapOID.0 type=6 value=OID: HH3C-STACK-MIB::hh3cStackPortLinkStatusChange
    HH3C-STACK-MIB::hh3cStackMemberID.2 type=2 value=INTEGER: 1
    HH3C-STACK-MIB::hh3cStackPortIndex.1.2 type=2 value=INTEGER: 2
    HH3C-STACK-MIB::hh3cStackPortStatus.1.2 type=2 value=INTEGER: 1
    I want to be abble to trigger when:
    HH3C-STACK-MIB::hh3cStackPortStatus.1.2 type=2 value=INTEGER: =1
    And I would like to close the trigger when:
    HH3C-STACK-MIB::hh3cStackPortStatus.1.2 type=2 value=INTEGER:=2
    But the value .1.2 (HH3C-STACK-MIB::hh3cStackPortStatus.1.2) do no have to be taken into consideration in the trigger, depending on the stack, the value can be diferent
    You help would be very appreciated, thanks in advance.
    Henri
  • hemh
    • Apr 2020
    • 43
    I tried to make a SNMP item like this: snmptrap[(hh3cStackPortStatus.(1-9).(1-9) type=2 value=INTEGER: 2)]
    but it doesn't work
    • hemh
      • Apr 2020
      • 43
      Ok, I gonna reply to myself, guess it could help HPE switches admin.
      So to make it work, I followed the SNMP trap procedure here: https://blog.zabbix.com/snmp-traps-in-zabbix/8210/ and here: https://majornetwork.net/2021/05/con...bix-on-debian/
      SNMP trap items took me a few days to set up, so here is the solution I made up:
      I created 2 items:
      SNMP traps (IRF Link DOWN) with key: snmptrap["hh3cStackPortStatus(.*)type=2(.*)value=INTEGE R.*)2"]
      SNMP traps (IRF Link UP) with key: snmptrap["hh3cStackPortStatus(.*)type=2(.*)value=INTEGE R.*)1"]
      Then I created 2 triggers:
      {HOST.NAME} IRF Link Down with this expression: {Template Module Generic SNMPv2:snmptrap["hh3cStackPortStatus(.*)type=2(.*)value=INTEGE R.*)2"].strlen()}>1 and {Template Module Generic SNMPv2:snmptrap["hh3cStackPortStatus(.*)type=2(.*)value=INTEGE R.*)2"].nodata(20)}=0
      {HOST.NAME} IRF Link is back UP with this expression: {Template Module Generic SNMPv2:snmptrap["hh3cStackPortStatus(.*)type=2(.*)value=INTEGE R.*)1"].strlen()}>1 and {Template Module Generic SNMPv2:snmptrap["hh3cStackPortStatus(.*)type=2(.*)value=INTEGE R.*)1"].nodata(20)}=0
      So the trigger close by themselves after 20s
      Then I created 2 actions:
      IRF Link DOWN with condition: Trigger name contains IRF Link Down and then send mail to network admins
      IRF Link is back UP with condition:
      Trigger name contains IRF Link is back UP and then send mail to network admins
      An it work fine
      • hemh
        • Apr 2020
        • 43
        I created 2 items:
        PHP Code:
        SNMP traps (IRF Link DOWN) with key: snmptrap["hh3cStackPortStatus(.*)type=2(.*)value=INTEGER:(.*)2"]
        SNMP traps (IRF Link UP) with key: snmptrap["hh3cStackPortStatus(.*)type=2(.*)value=INTEGER:(.*)1"]
        PHP Code:
        {HOST.NAME} IRF Link Down with this expression: {Template Module Generic SNMPv2:snmptrap["hh3cStackPortStatus(.*)type=2(.*)value=INTEGER:(.*)2"].strlen()}>1 and {Template Module Generic SNMPv2:snmptrap["hh3cStackPortStatus(.*)type=2(.*)value=INTEGER:(.*)2"].nodata(20)}=0
        {HOST.NAME} IRF Link is back UP with this expression: {Template Module Generic SNMPv2:snmptrap["hh3cStackPortStatus(.*)type=2(.*)value=INTEGER:(.*)1"].strlen()}>1 and {Template Module Generic SNMPv2:snmptrap["hh3cStackPortStatus(.*)type=2(.*)value=INTEGER:(.*)1"].nodata(20)}=0
        An it work fine
        Modified the post to get it mor readable.
        • dararg
          • Oct 2023
          Hello hemh! I have the same scenario at my work and your solution is very useful to me. Could you tell me how you configured the HPE switch to send the trap to the zabbix server?
