API not returning history data
  • fed135
    • Oct 2015
    Hi, I'm having a problem with a query to our Zabbix 2.4 instance. The problem only started happening recently.
    I'm asking the API for entries between two dates.
    "output":"extend",
    "itemids: ["200...],
    "sortfield":"clock",
    "sortorder":"ASC",
    "time_from":1442762167,
    "time_till":1444490167
    I'm getting no entries from the call for that specific range, but when I go on the website and show the graph for those itemids, I can see all of the data.
    Any ideas why I'm not getting the entries through the API ?
  • LenR
    • Sep 2009
    • 1011
    What is the API returning? An error or nothing?
    Check latest data to make sure you have history for that item, for that time range.
    Try without the time ranges....
    • fed135
      • Oct 2015
      No errors, just an empty dataset.
      The website shows data (through a graph) for the itemids
      Tried with no from/till and I'm still not getting data for my range, or any data older than 5 days.
      I've contacted our Zabbix admins to check if they moved or removed the data.
      I know that one app is hitting the zabbix instance on a fixed interval asking for the last 5 days, is it possible that Zabbix caches these results and returns them (even if it doesn't match the requested from/till) ?
