Temperature monitoring SNMP
  • Rapit
    • Nov 2021
    Good morning
    I have a problem because I have a cisco switch
    I would like to connect the temperature reading under zabbix because the switch has a sensor that checks the temperature in the room.
    I'm a newbie to zabbix
    At the moment I have connected the switch and I can see all interfaces in zabbix, can someone help me?
    Sorry, but my English is poor
    Thanks to everyone for your help
  • tim.mooney
    • Dec 2012
    • 1436
    Have you identified which SNMP object identifiers (OIDs) you need to query to get the temperature reading(s) that you care about?
    Have you read the Zabbix documentation, especially the chapter about configuration? You'll need to make sure that Zabbix is collecting data for the item(s) that have the temperature(s) you care about.
    • Rapit
      • Nov 2021
      When I connect to the switch via telnet, I use this command to display the temperature data :NAME-C4500#show environment temperature
      How can I connect it to zabbix to have all the information on the chart?
