Application for Zabbix
  • ggs_admin
    • Oct 2021
    • 44
    Hello everyone.
    I know that most of yours are already decorate the Christams tree but I have one question: What application you are using for Zabbix on Linux? As I know I can use Nagstamon but perhaps you are using better application..
  • ggs_admin
    • Oct 2021
    • 44
    If only elf (the deer is left alive) then nothing super serious.
    • ggs_admin
      • Oct 2021
      • 44
      Hey there,
      I have tried to add Zabbix user with the user type "Zabbix User" to the nagstamon tool in order to replace monitoring from Web interface to some tool but got the error
      When I have tried to add the user with the type Zabbix Admin then it is working properly for Nagstamon. But since I don't want to share the admin permissions due to security reasons.
      At the same time user type "Zabbix User" is working properly for Mozilla extension Zabbix Vue.
      Any thoughts regarding this? ​
      • ggs_admin
        • Oct 2021
        • 44
        The issue has been solved. But I'm still open to any recommendations for alternatives for nagstamon
        • ggs_admin
          • Oct 2021
          • 44
          Just noticed that Nagstamon and Zabbix Vue don't show all the critical information.
          For example, when the server is Unknown or Not available it doesn't show in the above-mention tools.
          Simply monitor Web dashboard isn't good idea.
