Using Item as Tag
  • neorejdv76
    • Nov 2021
    • 15
    Using Item as Tag
    HI,
    First post here
    I am struggeling with the following.
    on a host i am read out the contents of a file. This file gives back a word.
    Now i would like to use this item as the value of a TAG.
    I have tried to use a macro for it and then use the macro as value for the tag but that does not work.
    Is this even possbile to get a item as a tag?
    Any help will be apprciated.
    You can use items value as a tag name/value in trigger config. Point is to use that item in trigger expression...
    https://www.zabbix.com/documentation...ed_by_location
    {ITEM.VALUE<1-9>} → Trigger-based notifications and commands
    → Problem update notifications and commands
    → Trigger names, operational data and descriptions
    → Tag names and values
    → Trigger URLs7
