Monitoring FortiGate VPN tunnels
  • madis
    • Nov 2021
    • 9
    So I need to monitor statuses of several VPN tunnels. FortiGate has a great OID for that, fgVpnTunEntStatus (1.3.6.1.4.1.12356.101.12.2.2.1.20).
    snmpwalk gives me the expected output:
    [root@zabbix ~]# snmpwalk -v2c -c public 10.10.10.254 1.3.6.1.4.1.12356.101.12.2 .2.1.20
    SNMPv2-SMI::enterprises.12356.101.12.2.2.1.20.20.1 = INTEGER: 2
    SNMPv2-SMI::enterprises.12356.101.12.2.2.1.20.21.1 = INTEGER: 2
    or
    [root@zabbix ~]# snmpwalk -v2c -c public 10.10.10.254 FORTINET-FORTIGATE-MIB::fg VpnTunEntStatus
    FORTINET-FORTIGATE-MIB::fgVpnTunEntStatus.20.1 = INTEGER: up(2)
    FORTINET-FORTIGATE-MIB::fgVpnTunEntStatus.21.1 = INTEGER: up(2)
    In Zabbix I make an item prototype:
    Name: VPN tunnel status[{#SNMPVALUE}]
    Type: SNMP agent
    Key: fgVpnTunEntStatus[{#SNMPVALUE}]
    SNMP OID: FORTINET-FORTIGATE-MIB::fgVpnTunEntStatus.{#SNMPINDEX}
    Type of information: Numeric (unsigned)
    Now when I run a Test, I get the response:
    snmp_parse_oid(): cannot parse OID "FORTINET-FORTIGATE-MIB::fgVpnTunEntStatus.{#SNMPINDEX}"
    It's the same when SNMP OID is replaced with a numeric representation:
    snmp_parse_oid(): cannot parse OID "10.10.10.254 1.3.6.1.4.1.12356.101.12.2 .2.1.20.{#SNMPINDEX}".
    If I add a plain text widget on a dashboard, the VPN tunnel status [tunnel name] are listed, but the status is "not supported".
    If I substitute the {#SNMPINDEX} in SNMP OID with a real index, for example .20.1, the test runs successfully and I get a result "2".
    If I substitute the Type of information with Text, the test still fails, in the plain text widget the items are marked as "not supported", but they all return a value "1"
    The VPN Tunnel status item prototype is made under Network interfaces discovery rule:
    Key: ifName
    SNMP OID: discovery[{#SNMPVALUE},.1.3.6.1.2.1.31.1.1.1.1]
    I also tried to make a new discovery rule for VPN interfaces, from there I get the following results:
    discovery[{#SNMPVALUE},.1.3.6.1.4.1.12356.101.12.2.2.1.20]
    [{"{#SNMPINDEX}":"20.1","{#SNMPVALUE}":"2"},{"{#SNMPINDEX}":"21.1","{#SNMPVALUE}":"2"},...
    From there I can see that the numbers added to the OID really are called with a variable #SNMPINDEX.
    As this is my first time with Zabbix, I'm a bit perplexed...
  • MrB
    • Nov 2021
    I've been trying to do pretty much the same thing over the last couple of days, where I wanted to see the status of all my phase 2 tunnels. I got it working thanks in part to your post! Here's what I did:
    Create a new discovery rule, which will discover the phase 2 names:
    Name: VPN Phase 2
    Type: SNMP agent
    Key: fgVpnTunEntPhase2Name
    SNMP OID: discovery[{#SNMPVALUE},.1.3.6.1.4.1.12356.101.12.2.2.1.3]
    Then, I created an item prototype to get the status of each of the tunnels discovered:
    Name: {#SNMPVALUE}: Tunnel Status
    Type: SNMP agent
    Key: 1.3.6.1.4.1.12356.101.12.2.2.1.20.{#SNMPINDEX}
    The result is that I've got all my phase 2 tunnels discovered with their respective statuses. I think I'm also going add a couple more item prototypes to get traffic stats with fgVpnTunEntInOctets and fgVpnTunEntOutOctets.
    In reference to #SNMPINDEX, this is "A built-in macro containing index of the discovered OID is applied to discovered entities. The discovered entities are grouped by {#SNMPINDEX} macro value."
    Hope this helps...
    • madis
      • Nov 2021
      • 9
      Thanks MrB for making this week a successful one for me!
      Just to clarify for other readers, in the Item prototype, there are Key and SNMP OID fields - you only describe a Key field in your post. My final prototype looks like that:
      Name: Tunnel Status: {#SNMPVALUE}
      Type: SNMP agent
      SNMP OID: 1.3.6.1.4.1.12356.101.12.2.2.1.20.{#SNMPINDEX}
      Thanks again!
      • MrB
        • Nov 2021
        Aah yes, I messed up that second code block. What you have posted is the same as what I have.
        Glad you got it working!
        • bilal.habib
          • Apr 2020
          • 22
          You are both awesome!
          • bilal.habib
            • Apr 2020
            • 22
            For trigger you can use this
            HTML Code:
            Name: VPN Tunnel Down [{#SNMPVALUE}]
            Expression: last(/Template Net Fortinet FortiGate SNMP/fgVpnTunEntStatus[{#SNMPVALUE}],#1)=1
            Ofc you can change expression to what you wish
            • madis
              • Nov 2021
              • 9
              To add to this topic, there is a different OID for a dialup VPN tunnel:
              fgVpn2DialupTable 1.3.6.1.4.1.12356.101.12.4.1
              or even higher level OID to get all the info:
              fgVpn 1.3.6.1.4.1.12356.101.12
              More info can be found at https://docs.fortinet.com/document/f...new-oids-6-4-2 and https://oidref.com/1.3.6.1.4.1.12356.101.12
              What I can't find is an OID that would show the status of a dialup tunnel, similarly to fgVpnTunEntStatus for a regular tunnel. Can anyone suggest a workaround?
              • Cassemiro
                • Apr 2024
                good afternoon,
                managed to find out how to monitor phase 1 of the fortgate vpn through zabbix?
                • MarkS
                  • Oct 2023
                  Hi All. Does anybody found: how monitor dialup VPN tunnel statuses?
