Configure Custom intervals using Terraform
  • MarcoUK
    • Oct 2021
    • 26
    HI,
    I configured my item using Terraform provider https://registry.terraform.io/provid...ces/item_agent and works fine.
    resource "zabbix_item_agent" "verify" {
    hostid = data.zabbix_template.template.id
    key = "verify.failures"
    name = "verify"
    valuetype = "unsigned"
    delay = "5m"
    history = "7d"
    trends = "365d"
    applications = [zabbix_application.application.id]
    depends_on = [
    Now I see that this check start every 5 minutes but from (for each hour) 02,07.12.17,...etc is it possible to force it to start every 5 minutes but from 00.05,10,15,...etc?
    I read the doc https://www.zabbix.com/documentation..._preprocessing
    and if I understood I can set Custom intervals using variable
    delay
    But I tried using
    delay = "${5m}/${01-7,00:00-24:00}"
    or
    delay = "5m/01-7,00:00-24:00"
    but it doesn't work.
    Someone used it or have any advise to how can I solved my problem?
    There is plenty of examples in that page .. https://www.zabbix.com/documentation...stom_intervals
    Nowhere there can I see example using any of your proposed formats...
    • MarcoUK
      • Oct 2021
      • 26
      how can I set it?
        That documentation page did not help you ?
        Setting delay to "0;m/5" maybe? 0 - because you need to disable original delay and m/5 tells it to have scheduled interval of 5 minutes.
        Everythig according to api documentation..
        delay
        (required)
        string Update interval of the item. Accepts seconds or a time unit with suffix (30s,1m,2h,1d).
        Optionally one or more custom intervals can be specified either as flexible intervals or scheduling.
        Multiple intervals are separated by a semicolon.
        • MarcoUK
          • Oct 2021
          • 26
          delay
          (required)
          It works! thanks a lot!
