Delete host after X minutes/hours after it was added?
  • Failsloth
    • Jan 2019
    Hi there,
    I have a bit strange use-case of the Zabbix system, where I need to remove hosts automatically after some period, even if they're reachable.
    Any ideas, how to achieve that? I know that with autodiscovery it is possible to set this for the unreachable hosts, however, in this case they will remain reachable.
    Does anyone know how can I implement this, or can push me in the right direction? Thanks.
  • Hamardaban
    • May 2019
    • 2714
    the way: https://www.zabbix.com/documentation...ce/host/delete
    • Failsloth
      • Jan 2019
      Thank you, Hamardaban that'll do for a removal method.
      However, can I somehow use XML-API to obtain the host's age?
      Or perhaps, there is some event manager, that can trigger a command and pass the host id once new host is created?
      Thanks,
      • Failsloth
        • Jan 2019
        I've figured out, that the host creation date can be fetched from the zabbix auditlog DB table. Thanks
        • JavierOrellana
          • Apr 2024
          Hi Failsloth, i have the same use-case as you had.... can i ask if you manage to perform the autodelete process?
