Database connection
  • Goldengate
    • Oct 2015
    Database connection
    Hi fellow Zabbix admins!
    I have installed Zabbix in one HP server with Debian 8 "Jessie" with the repo files, the IP address is 192.168.1.6 but all my MySQL databases are in other server IP address 192.168.1.10. So I edit /etc/zabbix/zabbix_server.conf with:
    DBHost=192.168.1.10
    And in the file /etc/zabbix.conf.php
    $DB['TYPE'] = 'MYSQL';
    $DB['SERVER'] = '192.168.1.10';
    $DB['PORT'] = '0';
    $DB['DATABASE'] = 'zabbix';
    Now in my zabbix-server logs I get this:
    [Z3001] connection to database 'zabbix' failed: [1045] Access denied for user 'zabbix'@'192.168.1.6' (using password: YES).
    Database is down. Reconnecting in 10 seconds.
    I don't know if I'm missing something, this is very very weird.
    Any suggestions or ideas are welcome!
    Best regards!
    Frank
  • Atsushi
    • Aug 2013
    • 2028
    You must grant permission to zabbix user on your MySQL.
    I think you grant to zabbix user on localhost only.
    If you want access from remote host, you must create remote user and grant access.
    ex.
    mysql> grant all privileges on zabbix.* to 'zabbix'@'192.168.1.6' identified by 'password' ;
