[ZBX 5.4] Custom Trigger Prototype = Filesystem 100% Full
  • omar.cacciotti
    • Jul 2021
    • 25
    Hello everybody!
    Thank you in advance for any suggestions:
    I will try to explain my issue.
    SCOPE: Build a trigger prototype for Filesystems at 100%. This trigger must be an "evolution" of standard template triggers:
    Step1 —> /: Disk space is low (used > 80%) <--- this is the default template trigger that's working
    Step2 —> /: Disk space is critically low (used > 90%). <--- this is the default template trigger that's working
    Step3 ---> /: Disk space is 100% FULL (used = 100%). <--- this is the custom that isn't working
    After many tries I simplified the rules:
    {my_host:vfs.fs.size[{#FSNAME},pused].last()}={$VFS.FS.PUSED.MAX.FULL:"{#FSNAME}"}
    Where VFS.FS.PUSED.MAX.FULL = 100
Name:	Trigger prototype list.png
    I full cloned the AVERAGE trigger and modified some data:
Name:	Custom Trigger detail.png
    And this is inherited at host level:
Name:	Host triggers.png
    Any suggestion on how to solve the issue?
    This trigger not appears on the monitoring dashboard
    tnx!
  • tim.mooney
    • Dec 2012
    • 1436
    What is the client returning for percent-used (pused) on that volume?
    Your trigger is written so that it will only evaluate to a problem when the value returned is exactly equal to 100. I haven't tested whether the zabbix_agent's tests include the filesystem "minfree" setting, but it's possible (in some cases) that your volume may be full without returning exactly 100 as the percent used.
      I would go with >99% (or 99.8 or similar) instead of =100
