Hi.
I'm using several configuration files for my templates, for UserParameter items.
The problem is, that whenever I update a conf file, I then need to distribute it across my servers fleet.
Currently, I'm not using any Configuration Management tool, so I'm simply copying the amended files with scp. However, this is quite a tedious process, and I'm sure you have some idea to make this simpler...
BTW: Is there a way for Zabbix agent to read a remotely stored configuration file?
Thank you in advance!
