How to get values that compose a graph using the API
  • directcuteo
    • Nov 2021
    Hello! I am trying to create this graph using the API. I discovered that using the graphitem.get method I can get all the lines (green, yellow ...) that make up this graph along with their color, id, and other properties. Is there any way to retrieve all the points that make up this chart through a json API (not a HTML file as the Zabbix page is doing)?
Name:	Screenshot 2021-11-18 121312.png
    Thank you!
  • kreazy
    • Nov 2021
    Thank you!
    hello. I have the same question like you, How do you monitoring that
    • directcuteo
      • Nov 2021
      I managed to get the data using the history API: https://www.zabbix.com/documentation...ce/history/get
      • kreazy
        • Nov 2021
        I cant get data. Can you show me your json configure ?
        Thank
        • directcuteo
          • Nov 2021
          This is the request I used:
          "jsonrpc": "2.0",
          "method": "history.get",
          "params": {
          "output": "extend",
          "hostids": "123",
          "itemids": "123",
          "sortfield": "clock",
          "limit": 10
          "id": 50,
          "auth": "123123123"
          Just use proper hostId, itemId and correct auth id
