how to Zabbix Agent on Mac OS X
  • mdk
    • Jul 2014
    • 9
    Can any one tell me, how to install Zabbix Agent on Mac OS X?
  • ingus.vilnis
    • Mar 2014
    • 908
    You can install Zabbix agent on OS X by compiling it from sources as on any other UNIX system.
    Download the files, extract, and run the configure
    ./configure --enable-agent
    And follow the documentation for additional steps.
    Best Regards,
    Ingus
    • redtomato
      • Nov 2015
      Mac agent should be available as a binary for download
      Best Regards,
      Ingus
      That's all very well, but it would be better to have a binary ready for download exactly like it is the case for Windows, for instance.
      • coreychristian
        • Jun 2012
        • 159
        You could send a request to the zabbix dev team, or put it in the suggestion forum.
        The reality though is that monitoring OSX likely isn't very common so I am not sure if it's an RPM they would want to support.
        • webmaniac
          • Aug 2017
          osx agent
          Can you specify which agent to use there is no osx only different linux and unix ones?
          • gnuowned
            • Nov 2018
            The best way to do it is to install HomeBrew (http://osxdaily.com/2018/03/07/how-i...mebrew-mac-os/) then just run brew install --without-server-proxy and you are set :-D
            • jancs
              jancs commented
              # brew install --without-server-proxy zabbix
              Error: Running Homebrew as root is extremely dangerous and no longer supported.
              As Homebrew does not drop privileges on installation you would be giving all
              build scripts full access to your system.
              So - it does not "fly"
