Using proc.num to monitor Linux system process
  • lmnti33s
    • Sep 2014
    I'm trying to use proc.num to monitor a system process, which is enclosed in brackets.
    Example, ps -ef | grep ipvs returns the following
    root 5581 2 0 Oct08 ? 00:33:18 [ipvs_syncmaster]
    My key looks like proc.num[,root,,ipvs] but zabbix returns 0. In fact, it seems to return 0 for any process enclosed in brackets.
    Any thoughts?
  • ingus.vilnis
    • Mar 2014
    • 908
    Just give a try to the following key:
    proc.num[,root,,"[ipvs_syncmaster]"]
    Does it return any result other than 0? Also you can try to remove the user from item key and go with the name only.
    Best Regards,
    Ingus
