Periodically run "Check Now" for ITEMS
  • irwan13th
    • Apr 2020
    Hi guys,
    Currently running Zabbix Agent 4.0LTS, Windows 2016 and reporting back to Zabbix Manager 4.0, RHEL7. Need help with issue on Disk Usage [ITEM].
    Having some issues that the LatestData for Disk Usage is not collecting the data for every interval.
    Interval is set to 1H but there are times when 2-3 hours without any data, sometimes 14-18 hours as well.
    I am still troubleshooting as it may be OS, network or environment issue but in the meantime, I would like to have it check for at least every 2 hours.
    Using the [Check Now] button on the ITEM page works but am thinking if there are some specific command that I can run via the terminal on Zabbix Manager?
    This way I can write the script and run in periodically using crontab...
    Appreciate any suggestions..
  • splitek
    • Dec 2018
    • 101
    You can:
    - use "nodata" function in trigger
    - use "zabbix_get" https://www.zabbix.com/documentation...l/concepts/get
    - use agent test ("-t") parameter https://www.zabbix.com/documentation...concepts/agent
