Convert String to Integer on zabbix
  • higor
    • Jan 2020
    Heello i have one issue about the zabbix interaction with AWS CloudWatch.
    so, i'm using one script that make call to CloudWatch then take some information(for exemple: CPU avarage) and i'm using External script to do this job, But when i recieve the content of response on zabbix the content arrive as string but i need it to be a Integer to use unit in %.
    Do you know how i can do this?
  • ISiroshtan
    • Nov 2019
    • 324
    I see it complaints that it's a string, but would you be so kind as to first change "Type of information" of your item to "Numeric (float)", to be inline with what you actually receiving, and then try again to push new data? Pretty sure it should solve your problem.
      Agreed. I have seen it before, when using int instead of float.
      That error message is a bit off tho... Not saying that "your float number does not fit unsigned int filed" but "string is not fitting unsigned int"... Confusing.
      • higor
        • Jan 2020
        If i change the item and alter the type to "string" like a Text, log etc... It's work because the value that i'm receiving of the script for zabbix is string and i don't know why. but i need one number(integer or float)
        • ISiroshtan
          • Nov 2019
          • 324
          Did you try to set it to "Numeric (float)"?
          • higor
            • Jan 2020
            yes, in this image is in "numeric (float)"
            • ISiroshtan
              • Nov 2019
              • 324
              In the image you added to initial question it clearly states ".. not suitable for Numeric (unsigned)..."
              • higor
                • Jan 2020
                yes... the issue is "how i can send this value as a Numeric using external ecripts" it's possible?
                • vicbc
                  • Nov 2021
                  • 39
                  Hey Higor.
                  Just as ISiroshtan said: As long as it`s values is formated as numeric (float), it should be responding to Zabbix as such.
                  Take a double check just to confirm that the item type is Numeric(float).
                  If the problem persists, try to run the script on shell, and verify the value. Check if the result doesn't have double quotes (" ") around it (which would make it a String value).
                  If you make those verifications, and it still doesn't work, could you send your script so we can take a quick look at it?
                  Cheers
