Latest Data Help
  • JamieTalbot5
    • Nov 2021
    Latest Data Help
    I am having an issue on Zabbix where I have imported a template for a WatchGuard Firebox which is pulling data fine. However, instead of pulling the interface names it's a random string of numbers (shown in the image attached).
    Does anyone have any ideas to how I can get Zabbix to pull the actual interface name rather then just some random numbers?
    Best Regards
    Jamie
  • vicbc
    • Nov 2021
    • 39
    Hey Jamie.
    Zabbix is simply getting the information displayed in the OID.
    Since the SNMP items keys are discovered by this template, you should take a look at the MIBs file and OID information of the Watchguard.
    Try running snmpwalk at your device and other snmp commands to verify if those are the actual names the device is returning.
