Worried about zbx 6 and snmp cisco template
  • propusgemini@gmail.com
    • Mar 2018
    • 108
    Hi, I'm a little worried.
    I will have to monitor about 10k cisco switches, I studied the scenario on zabbix 5.4 through an SNMP Cisco Template and the tests were ok. However, the company will launch the project in January 22 and they would like use zabbix 6. Do you think that something will change with cisco switch snmp monitoring? if this type of monitoring will change, I will be in a trouble
    If they would go from 5LTS to 6LTS, then I would be more worried, than going from 5.4 to 6... There were significant changes between 5.0 and 5.4.. like all the expressions language etc. going from 5.4 to 6 is much easier.
    The other thing is, getting final version of 6 out by Jan22... Questionable.
