Same values in the log (output in the trigger name)
  • ErmTV
    • Dec 2021
    Hello! I am having problems when configuring the output of values from the log to the trigger.
    We have a log windows event viewer and event 4720 (user creation):
    A user account was created.
    Subject:
    Security ID: Contoso\Administrator
    Account Name: Administrator
    Account Domain: Contoso
    New Account:
    Security ID: Contoso\Username
    Account Name: Username
    Account Domain: CORP
    I want the following values to be displayed in the trigger name: Administrator created the user Username.
    Previously, I used {{ITEM.VALUE} .iregsub to grab values from the log, but now I can't do that because the Security ID, Account Name and Account Domain values are the same for both the user who creates the account and the created user.
    Please tell me how to be in such a situation when it is necessary to display such values? Sorry for my english.
  • Answer selected by ErmTV at 03-12-2021, 14:35.
    ISiroshtan
    • Nov 2019
    • 324
    Looking at screenshot and text I have a strong feeling tabs were removed from text by forum engine when you posted.. still tried to account for it. Please do try the following:
    1. Trigger name:
    {{ITEM.VALUE}.regsub("Account Name:\s*(.*)",\1)} created the user {{ITEM.VALUE}.regsub("New Account:\s*Security ID:.*\\(.*)",\1)}
    2. Trigger name:
    {{ITEM.VALUE}.regsub("Account Name:\s*(.*)\n(.|\n)*?Account Name:\s(.*)", "\1 created the user \3")}
    • ISiroshtan
      • Nov 2019
      • 324
      Hi there.
      Please try following approaches, pretty sure both of them should work(tested on my LAB with Zabbix 5.0).
      1. Trigger name:
      {{ITEM.VALUE}.regsub("Account Name: (.*)",\1)} created the user {{ITEM.VALUE}.regsub("New Account:\nSecurity ID: .*\\(.*)",\1)}
      2. Trigger name:
      {{ITEM.VALUE}.regsub("Account Name: (.*)\n(.|\n)*?Account Name: (.*)", "\1 created the user \3")}
      • ErmTV
        • Dec 2021
        Originally posted by ISiroshtan
        Hi there.
        1. Trigger name:
        2. Trigger name:
        Hello.
        I tried to paste the code you suggested now.
        When using the first option, only "created the user" will remain in the trigger name
        When using the second option, the trigger name is empty.
        I just pasted the options you suggested in the trigger name, did I do the right thing?
        • ISiroshtan
          • Nov 2019
          • 324
          Please kindly specify which version of Zabbix server you using and add a screenshot showing how said information appear in "Latest data" inside of Zabbix.
          • ErmTV
            • Dec 2021
            zabbix_server (Zabbix) 5.0.11
            Revision 15ae5548ce 26 April 2021, compilation time: Apr 26 2021 11:24:33
            • ISiroshtan
              • Nov 2019
              • 324
              Ok, can you copy me data from "Latest data" as text(feel free to replace domain and usernames with whatever you want)? The data contains extra spaces/tabs/new lines, which I obviously did not account for when writing the regexp.
              • ErmTV
                • Dec 2021
                Attached! Thank you so much for your attention to my problem!
                Subject:
                Security ID: CONTOSO\Administrator
                Account Domain: CONTOSO
                Logon ID: 0x0000000
                New Account:
                Security ID: CONTOSO\testauditt
                Account Name: testauditt
                Attributes:
                SAM Account Name: testauditt
                Display Name: testauditt
                User Principal Name: [email protected]
                Home Directory: -
                Home Drive: -
                Script Path: -
                Profile Path: -
                User Workstations: -
                Password Last Set: <never>
                Account Expires: <never>
                Primary Group ID: 111
                Allowed To Delegate To: -
                Old UAC Value: 0x0
                New UAC Value: 0x00
                User Account Control:
                Account Disabled
                'Password Not Required' - Enabled
                'Normal Account' - Enabled
                User Parameters: -
                SID History: -
                Logon Hours: <value not set>
                Additional Information:
                Privileges
                • ISiroshtan
                  • Nov 2019
                  • 324
                  1. Trigger name:
                  2. Trigger name:
                  • ErmTV
                    • Dec 2021
                    1. Trigger name:
                    2. Trigger name:
                    It works!!! Thank you very much!
                    • ErmTV
                      • Dec 2021
                      1. Trigger name:
                      2. Trigger name:
                      Hello!
                      Could you tell me how it works? So that I don't write to the forum every time +)
                      For example, we have a line:
                      What the parameters "\ s *" "\ 1" "(. *)" Mean. Please tell me where you can read about it?
                      • ISiroshtan
                        • Nov 2019
                        • 324
                        Hey there mate.
                        https://regex101.com/ - generally a good utility to test a regexp. But be mindful as regexp from this website sometime needs to be changed slightly to comply with PHP and Zabbix parsing (notable the use of " inside of regexp that needs to be escaped by backslash). Also, you need to disable global and multiline options on this website
                        You can use wiki for some theory + some cheat sheet:
                        javascript,regex,regular expression,visual,nfa,dfa,state,debugger,helper,tester,match,random match
                        https://en.wikipedia.org/wiki/Perl_C...ar_Expressions
                        Also you can reach me in personal message and we can have discussion if you need to know something in particular.
                        Still, to answer your questions on specific symbols:
                        \s - any whitespace character, including but not limited to space, tab, new line.
                        \s* - any number(including zero) of whitespace characters
                        (.*) - match any number of any characters (in non multi-line mode it will match up to a new-line character) and remember them as a "match group"
                        \1 - return whatever you remembered as a group 1 (also not really part of expression itself but an output syntax that is also supported in Zabbix )
                        Hope it helps.
