Enable multiple Trigers
  • Antivilf
    • Nov 2021
    I need to Enable lot of triggers (about 7-9 thousand total) created from Trigger Prototype Discovery for lot of servers.
    Is it possible to do it automatically without spamming to Audit ?
    Or maybe i can apply Trigger Prototype Discovery for already existing servers?
  • vicbc
    • Nov 2021
    • 39
    Hey there Antivilf
    I don't know if i've got it right, but you can enable them from the discovery rule you're using. Just set them as "Create Enable".
    You can also create a "Trigger Prototype Discovery for already existing servers".
    You can add them to the discovery rule used by the template you're using, and let the magic happen.
    Cheers.
