How to use a value from JSON in LLD Macro/Variable
  • MMol
    • Nov 2021
    We are trying to monitor a few things related to Microsoft Graph. For this we need to POST for a Bearer token first. This works in an item:
    https://login.microsoftonline.com/{$TENANT.ID}/oauth2/v2.0/token
    This returns the following:
    {"token_type":"Bearer","expires_in":3599,"ext_expi res_in":3599,"access_token":"TOKEN_STRING_HERE"}
    Then we created a discovery rule with a preprocessing rule:
    JSONPath : $.access_token
    This returns the full Bearer token as value for this, but how can we use this as a variable/macro?
    As the LLD Macro function needs a JSON path this doesn't work, there is just a string which is the token.
    If we remove the preprocessing rule, and create a LLD Macro:
    {#BEARER} : $.access_token
    Then Zabbix returns
    Cannot find the "data" array in the received JSON object.
    When discovering SNMP, we can use {#SNMPVALUE} which returns the value of the discovery. Can it be as simple as that for HTTP agent?
    Any solution would be appreciated!
  • Hamardaban
    • May 2019
    • 2713
    There is a special items type for such requests:
    https://www.zabbix.com/documentation...emtypes/script
    In it, you can do a multi-pass, step-by-step receiving of the necessary data using JS.
    • MMol
      • Nov 2021
      If I read this correctly, this uses variables/parameter but does not create them from the result of the script or API call.
      • Hamardaban
        • May 2019
        • 2713
        Using this element, you get a token at the first step and use it in the next request. After that, you can do anything with the received data. In particular, if the result is json -use it further in LD.
        • MMol
          • Nov 2021
          Alright, so as how I understand you are suggesting the script gets the token AND the JSON data in the same script. After that I can process the JSON data as I like?
          Is JavaScript the only supported language in type "Script"? Or can I also work with Python?
        • MMol
          • Nov 2021
          Do you know any examples? As the link you send only shows how to do HTTP GET, we also need POST. But when I try to Google they all use other methods like JS Fetch, jQuery or XHR. These do not seem to work inside Zabbix.
          I need a little help where to start on learning to use JavaScript.
          • lptarik
            lptarik commented
            Hello did you solve your issue?
          • MMol
            MMol commented
            Solved it by using a script for an item, and sub items that discover from this data. Have a look at the documentation. It's actually pretty straight forward. I did not know any JS
