Zabbix_agent2 Oracle plugin
  • gspoli
    • Dec 2021
    I've installed Zabbix 5.4 with zabbix_agent2.
    Configured the connection to database, it discovered the pdbs and tablespaces, but just tablespaces form the CDB.
    Do you know how is it intent to work? Just CBD tablespaces? How to colect data from PDB's tablespace.
    SQL> conn /as sysdba
    Connected.
    SQL> show pdbs
    CON_ID CON_NAME OPEN MODE RESTRICTED
    2 PDB$SEED READ ONLY NO
    3 ORCL3DBPDB READ WRITE NO
    4 PDB2 READ WRITE NO
    5 PDB3 READ WRITE NO
    Tablesapces from CDB - witch where discovered
    SQL> select tablespace_name from dba_tablespaces;
    TABLESPACE_NAME
    SYSTEM
    SYSAUX
    UNDOTBS1
    TEMP
    USERS
    Tablespaces from PDB2, not discovered
    SQL> alter session set container=PDB2;
    Session altered.
    TABLESPACE_NAME
    SYSTEM
    SYSAUX
    UNDOTBS1
    TEMP
    USERS
    NOASM
    Thanks.
