Zabbix web interface - can i change the base url
  • Alex_SYB
    • Feb 2012
    • 133
    Hi
    I have an old install on https://zabbix/
    I want to add a dedicated prod zabbix install i was thinking to put it under
    and then expand it to
    to cover the rest
    once done I could remove the old origin zabbix that was under https://zabbix/
    quick glance at the doco suggest you can put behind nginx - which is what i have but i can't find anywhere where i can change the base url
