Zabbix Timeout after 15 seconds
  • Lukecliff
    • Dec 2021
    • 12
    We have a fairly new zabbix setup on a linux server.
    I am now getting this error. Evertything was working compeltely fine lastnight and at 4pm all hosts stopped generating data and zabbix no longer updates "latest data"
  • vicbc
    • Nov 2021
    • 39
    Hey Luke.
    Some quick questions:
    Do you have a all-in-one installation (Frontend, Zabbix Server and Database)?
    Can you get us some log info from Zabbix Server (/var/log/zabbix/zabbix_server.log)?
    Cheers.
    • Lukecliff
      • Dec 2021
      • 12
      Originally posted by vicbc
      Hey Luke.
      Cheers.
      Here are the logs:
        First of all, do as logfile says. Increase CacheSize config parameter.
        • vicbc
          • Nov 2021
          • 39
          One little point of attention: please don't tell me that you're using Zabbix 6.0alpha7 in production.
          As cyber said, you should take a look at the CacheSize config parameter.
          What's the configuration of your server (RAM, CPU, etc?)
          Cheers,
          • Lukecliff
            • Dec 2021
            • 12
            Cheers,
            This is fixed now - is there an easy guide to follow to update from Zabbix 6.0alpha7 to the latest correct build?
              v6 does not have official release yet... latest is beta1 from yesterday... Probably better than any alpha version, but still something, that should not be used in production environment yet...
