Trigger str function for at least some time
  • joanaribeiro_erre
    • Jul 2020
    • 25
    Hi everyone,
    i need to create a trigger similar to the str function but with the min function too, meaning i want the problem to trigger if a str is found for at least one hour straight, for example.
    does anyone know how to accomplish this?
  • tim.mooney
    • Dec 2012
    • 1432
    How you accomplish this depends upon what version of Zabbix you're using. You didn't provide that information, so it's not possible to know what the best way of doing it would be.
    If you're using Zabbix 5.4 or later, have you looked at the new trigger syntax, and how you can combine ("wrap") trigger functions with other trigger functions?
    • joanaribeiro_erre
      joanaribeiro_erre commented
      Hi there, thanks for the reply and sorry for not giving all the info, my bad!
      I have zabbix 5.0! So no, cant use those yet
  • tikkami
    • May 2018
    • 71
    Count -function might be usable in this case.
