LLD macro in javascript preprocessing for an item prototype
  • jbdenis
    • Apr 2020
    Hello everybody,
    I'm stuck with Zabbix 5.0 at the moment, and I'm wondering if there is a way to use LLD macro inside javascript preprocessing step for an item prototype. The documentation mentions the possible use of user macros, but LLD macros does not seem to work.
    For example, in the context of vfs.dev.discovery item, if I create an item prototype with this preprocessing javascript code, the item value will literally be {$DEVNAME}, without resolution.
    function (value) {
         return '{$DEVNAME}';
    Do you know if that's possible or if it is a limitation of 5.0 ?
    Thank you for you help.
  • jbdenis
    • Apr 2020
    My mistake was in:
    It should be:
    return '{#DEVNAME}';
    Problem solved.
