Fortigate: Monitor Linked Fortiswitch + Fortivoice
  • Lucas007
    • May 2021
    I need to monitor fortiswitch linked to fortigate devices, just like the template for monitoring forti APs linked to fortigate devices; But i dont find any template to do that, i already search the forum and nothing.
    Is there any template to monitor fortiswitch equipements, managed/administered from the fortigate device? not the template for monitor the fortiswitch directly, but a template for the fortigate to inform me all the stuff related to the fortiswitch managed by the fortigate.
    And i need also a template for FortiVoice, anybody knows some template for FortiVoice?
    I have been searching a couple of hours and i havent been able to find any zabbix template for doing this two things
    Any Help would be much appreciated.
    Thanks in advance
    Lucas
    • 4996
    Couple of hours did not lead to results? Good luck building, what you need...
    • Lucas007
      • May 2021
      So i should do it manually myself, the thing is im very new to zabbix, i dont know how to write my own queries or build my own templates yet, maybe i am able to do it, but i´ve never done it before.
      So, any tip? to start, any place to learn or document to read? im working with fortinet devices, and i need to start monitor many aspects of this devices, that i dont find in any template for fortinet over the usual repositories.
      Thanks in advance
        • 4996
        Make sure you understand concept of items, triggers etc. then look up SNMP items and discovery and experiment, experiment, experiment. There are definitely some general SNMP templates available, where you can look up techniques, tips and tricks but they sure do not work for everyone and in every situation.
        Creating templates for specific things takes time, not everyone is ready to just share for free the results of hours/days/weeks work...
        None of us knew those things in the beginning, it is years of work behind the knowledge.
        • Lucas007
          • May 2021
          Ok, i do understand items, triggers, active & passive checks, and something else too. I will do it, i will start by investigating the template for FortiAPs (linked to fortigate), which one is working ok right now, and I will try to copy those items and discovery rules, and will go modyfing trying to make it work for the things we need.
          I do imagine that these things take time, a lot sometimes, i will try to share my results anyway.
          I will be posting here any advance or questions about it, if there is no problem about it, for others to be useful also.
          Thanks a lot for the guidance, wish me luck
          Cheers from Argentina
