Error when using Item to Populate Host Inventory - Zabbix 5.4.8
  • jmedlock
    • Mar 2021
    Hello my fellow Zabbix enthusiasts,
    I have come across an interesting bug that maybe somebody has come across already. Before I get into my tale, I want to preface with there haven't been any changes made in the last month. And everything has been working perfectly until the last couple of days. I'm also the only person who has access to the backend of the server.
    If I create an item on a host and populate an inventory field, everything works as its suppose too. However, if I create an item in a template and try to populate an inventory field, when I apply the change, I am greeted with a blank page. The side bar still shows up, but the main window where all the good stuff is, is nothing but blank.
    So I pulled up the developers console and repeated the process of creating (or modifying) an item in a template and try to populate an inventory field. This time when I submit the change, in the developer menu I see that there was an issue with the items.php file when the item is submitted. I've attached a screenshot of what I'm seeing so it might help someone.
    Any help on this would be immensely appreciated
    If you can replicate it easily, submit a bug report to https://support.zabbix.com/projects/ZBX/ it will be verified and fixed.
