My zabbix web page seems to be a static page
  • Kaizhao
    • Dec 2021
    Hi guys, i got stucked during my zabbix installation and setup. And I am now asking for your precious advice to help me get it done. I would be really thankful to you, if you try to help me with this.
    First of all, I did my LAMP installation and environment setup, and then zabbix installation. All of them were installed from sources. And when I went to zabbix web, I found that there is no choices bar after 'database type' , also it showed 'cannot connect to the database' after I filled the correct database info into the blanks. I took a picture of such situation and attached it here as the first picture. After this, I found a way to solve such problem is that make your own zabbix.conf.php, which I did, and this time, it finally works. It shows the login page of zabbix web. BUT, after I logged in with admin account, the web page seems to be a static page that when i click on bars like 'user settings', 'inventory', 'reports', etc., it showed no response. And I openned the console of the page, it shows 'jQuery is not found'.
    i am realky confused right now, I thought it might be zabbix web and zabbix_server were not connected, but my zabbix_server runs well on my linux machine and the IP and port of the server was also correct in file zabbix.conf.php.
    please give me some advice if you know anything that might help, would be grateful for that.
    the second attached photo is that when i click on the bar 'user settings', it's not working. the third photo is the error message in console of zabbix dashboard.view web page
  • gofree
    • Dec 2017
    • 400
    why install it from sources - any particular reason ? In my experience its simply not worth it if not necessary for some obscure reason but if you do you have to check all the prerequisites that needs to be there - especially for fronted in your case and additionally sometimes the LAMP components needs to be installed ( compiled ) with parameters showing where the other components are. It could be a mess Zabbix binaries are just fine usually , compilation of the LAMP is that can cause issues Unfortunatelly I cant see your pics ( my browsers just dont like attached pictures in Zabbix forum ) so my advise is rather general. Check also forum is somebody faced simillar thing.
    https://www.zabbix.com/documentation...n/requirements
    • littlelizard
      • Apr 2023
      Has it been resolved? I am using version 52.3 of Firefox browser.
