Help trigger with history data
  • andvsilva
    • Aug 2020
    • 39
    Hey guys,
    Can anyone help me with a trigger.
    I need to create a trigger to validate the last 5 hours from now if the item value is equal to '3' if there is any value different of '3' in the last 5 hours the alert should not be closed.
    I tried, but it didn't work. This is recovery expression:
    count (/ITEM.LASTVALUE,4m:now-1h, "eq", "3") = 1
    This is a trigger problem:
    count (/ITEM.LASTVALUE,#3, "ne", "3") = 3
    I'm following zabbix doc, but I probably got something wrong:
    4 History functions (zabbix.com)
    Thank you for your help.
  • Answer selected by andvsilva at 21-12-2021, 20:09.
    ISiroshtan
    • Nov 2019
    • 324
    I'm not sure I understood it precisely, but let me try to answer and you correct me if my understanding is wrong.
    TASK:
    You have the trigger that properly fires up. You just need to close it only if ALL values in last 5 hours are "3". If ANY of the values in last 5 hours is not "3" - don't close the alert.
    Now
    means that if you have exactly one value "3" in between 64 and 60 minutes ago - close the trigger. Which does not really sounds like what you trying to achieve.
    Please try this recovery expression:
    count (/ITEM.LASTVALUE,5h,"ne",3) = 0
    or
    count (/ITEM.LASTVALUE,5h,"ne","3") = 0
    • ISiroshtan
      • Nov 2019
      • 324
      TASK:
      Now
      or
        • 4957
        ITEM.LASTVALUE ? Should it not be /host/key there?
        I'm getting a bit suspicious if someone uses macro names with wrong format.. Never know, what they mean exactly..:P
        • andvsilva
          • Aug 2020
          • 39
          TASK:
          Now
          or
          Hi thanks for your tip, it worked.
          count (/host/key,5h,"ne","3") = 0
          But why the value is '=0' what is that mean? I don't get why in count I need to set on this way.
          This expression say 'count in the last 5 hour if the value is different of "3" ' so 0 is 'false' and 1 should be 'true' ?
          • ISiroshtan
            • Nov 2019
            • 324
            Hi there mate.
            Count is a bit different. It's not a true/false expression. It returns number of matched value. So what we ask here of Zabbix is: "count the values in last 5 hours. But only count values that are not '3' ". If Zabbix counted 0 (meaning it found no non-3 values) - then resolve the problem.
            If it would find any non-3 values, Count would return the number of those values. So 1,2,3, etc.
            Hope it helps mate.
            • andvsilva
              • Aug 2020
              • 39
              Sorry my mistake, but i'm using /host/key. I just write down in the wrong format.
              • andvsilva
                • Aug 2020
                • 39
                Hi there mate.
                Hope it helps mate.
                Hi mate,
                All right thanks for explanation. I'm reading doc now and undesrtood your answer.
                Thanks a lot.
