Problem with "Last 20 issues"
  • zzBernie
    • Apr 2015
    • 14
    Using Zabbix 2.2.8, my "Last 20 issues" on the dashboard does not seem to be displaying the correct issues. The dates of many of the issues are weeks old. And it ONLY displays "Free disk space is less than" issues.
    Does anyone know how to get Zabbix to display the current issues?
    I've tried rebooting Zabbix, acknowledging the issues, but that does not help.
  • LenR
    • Sep 2009
    • 1011
    Resolved issues disappear from Last 20, so it's really the 20 newest unresolved issues.
    Last 20 will only show systems in your permission scope and is effected by your profile settings.
    Try a web user with super admin and with profile disabled.
    • zzBernie
      • Apr 2015
      • 14
      My point is that the only issues that are shown are about a month old. It is not updating for some reason. I am a zabbix super user, and have permissions to access everything. I'm not sure what you mean by "web user" and "disable profile". How do you disable a profile?
      It's currently November 13th, here is a screenshot of issues, most of which are about a month old.
Name:	zabbix issues.jpg
      • LenR
        • Sep 2009
        • 1011
        I meant to check the Dashboard filter, the wrench icon at the upper left.
        Check latest data for the host and item alerting, are you getting updates? Is the value still above the trigger level?
        I wonder if these are LLD disks that are no longer discovered?
        • zzBernie
          • Apr 2015
          • 14
          I just checked the dashboard configuration and everything appears normal, i.e., Problem display = All, Host groups = All, everything is checked, etc.
          Now for some reason, my queues are always 0. That does not seem right, does it?
Name:	zabbix queues.jpg
