Zabbix Agent SNMP Check Local Network Device
  • Babel
    • Dec 2021
    Hello everyone!
    I'm currently trying to monitor a network device connected to a remote host based on Windows with Zabbix agent2 installed.
    So I've created a new SNMP interface on the host (192.168.168.1) and created a few items. However, it's the Zabbix server that's trying to connect to that IP instead of the local agent on the Windows Host.
    Is this possible to achieve? I think this is doable but I cannot make it work.
    I'm using Zabbix Server 5.0
    Thank you all!
    This does not work this way... SNMP checks are performed by server or proxy, not the agent on your host. You cannot force your agent to do those queries.
    • Babel
      • Dec 2021
      Hello cyber thank you for your answer. Is there any way I could achieve that monitoring?
