I've a question about the Zabbix Agent TImeout option. For Example if I run a remote command and its execution reaches the timeout, the Zabbix Agent is "timeouting" (kiling) the process which was executed or only sends the timeout information to Zabbix Proxy/Server?
If it is killing a process, do You know the way how to start the commands that will run for longer than the Timeout value and won't be stopped until the end of execution?
