Add custom URLs to hosts
  • Tobbeh
    • Oct 2015
    in our current monitoring system, that we are moving away from, we have for every host URLs built by macros:
    telnet://10.0.0.1
    ssh://10.0.0.1
    ping://10.0.0.1
    The protocols are registred with the corresponding application in our web browsers. So when we click for example telnet://10.0.0.1, it starts TeraTerm and we just have to login. This saves us a lot of time.
    Is it possible to do this with Zabbix? I tried with the URL A, B & C fields under Host inventory but any other protocol than HTTP and HTTPS becomes not clickable.
    We are using Zabbix 2.4.7.
  • Atsushi
    • Aug 2013
    • 2028
    If it is in the map, you can add URLs to the icon on the map.
    • Tobbeh
      • Oct 2015
      Hi, and thanks for your suggestion but the MAP URLs doesn't seem to like the Macro variable {HOST.IP}?
      Also, for our case, as we have over 3500 host distributed over 850 host groups it seems a bit unpractical to create and manage and search around the 850 maps for this feature.
