Dashboard graphs/Line continues until next val
  • vitS
    • Apr 2021
    • 43
    I have UserParameter with sql query. At this moment I ran query each 5 minutes - values go to graph on dashboard, which refreshes each 15 minutes.
    I don't want to run this sql query so often, so I put once per day - as a result on graph all lines disappear.
    Is it possible:
    Run UserParameter - Get value - Put this value as a start point on graph and this line continues by it self till next refresh?
    Or maybe You already have other solution for this.
    Thank You,
  • incama
    • Jan 2015
    • 66
    Just change the "Time period" of the graph to a minimal of one day (eg now-24h) or even better to a few days.
    • vitS
      • Apr 2021
      • 43
      Thanks, I didn't know about it.
      I will use it.
      Thank You,
