Zabbix with ssh tunneling
  • radi
    • Oct 2006
    Hi @ all
    How can i connect zabbix server with remote hosts?
    OS: Linux Suse 9.2
    thx a lot
    radi
  • mbjoerling
    • May 2006
    • 52
    Hi.
    Do you mean make a SSH tunnel to another server and then connect through that to the Zabbix server?
    • radi
      • Oct 2006
      Yes, I need a script, so that i can monitoring some remote hosts!
      example
      10.2.x.x (Zabbix Server) --> remote with ssh to 156.x.x.1 (Zabbix Agent is installed)
      10.2.x.x (Zabbix Server) --> remote with ssh to 156.x.x.2 (Zabbix Agent is installed)
      10.2.x.x (Zabbix Server) --> remote with ssh to 156.x.x.3 (Zabbix Agent is installed)
      • mbjoerling
        • May 2006
        • 52
        Make some underlying tunnels on the server with OpenSSH and then tell the server to connect to localhost:localboundclientport. That should do the trick.
        • den_crane
          • Feb 2006
          • 272
          I think iptables allow create rule forward remoteserver_port -> localhost_tunelport.
          • radi
            • Oct 2006
            Can someone make a example for this network configuration...
            Configuration now:
            SERVER
            IP: 10.2.x.x
            USER: zabbix
            zabbix_server.conf:
            - ListenPort: 10051
            CLIENTS
            IP: 156.x.x.1
            IP: 156.x.x.2
            IP: 156.x.x.3
            USER: zabbix
            zabbix_agentd.conf
            - ServerPort: 10051
            - Hostname: localhost
            - ListenPort: 10050
            My example (doesn't work):
            ssh -l zabbix -fN -L 10050:156.x.x.1:10050 -L 10051:156.x.x.1:10051 156.x.x.1
            And how can I add this remoteclient in "Webinterface: zabbix --> configuration --> hosts"?
            thx for your helps!
            radi
