report test ca certificates error
  • golg3
    • Oct 2021
    • 16
    Hi, I see an error like this on the report page;
    Details Report generating test failed. Cannot connect to web service: peer certificate cannot be authenticated with given CA certificates
    NOTE: I am forcing my access to the Zabbix web interface https
  • golg3
    • Oct 2021
    • 16
    help please
      I have not used that new report generator, but I think it is working as different service, independently from rest of the UI. So yo need to go over the report service setup here, I think...
      • golg3
        • Oct 2021
        • 16
        I solved the problem.
        We have uploaded our company ssl certificate to the Zabbix login page. It was generating ca certificate error while generating report. I added our company certificate to the ssl.conf file in zabbix and solved the problem.
        Thanks.
        • vai
          vai commented
          will you please share the steps to enable https using company certificate? thanks
      • Russel
        • Jan 2022
        Thanks for posting i have uploaded my company ssl certificate to the login page and unfortunately i was facing the same issue i and now i will try this out hope this will help me out keep posting.
        • Israe
          Israe commented
          hello! did it work for you? and if yes, can you pls share the steps with the files you configured please!!
