Value of item
  • rvanderkooi
    • May 2019
    • 33
    Value of item
    I am new here and try for first time create a template for my PDU.
    I have create some items, but with the "wrong" output.. i mean example my PDU give data for Ampere 1.1 A but my snmp value is in CentiAmpere 110 CentiAmpere.. how can i get the value from 110 to 1.1 ?
    Same for Voltage, i its 231.1V but snmp output is 23110 CentiVolt.
    Many thanks for reply.
  • Answer selected by rvanderkooi at 04-01-2022, 19:28.
    rvanderkooi
    • May 2019
    • 33
    I have see them item. but 1 ding i doesn't understeand. can you help mee?
    output of snmp walk is: SNMPv2-SMI::enterprises.31034.12.1.1.2.7.2.1.5.24171.1 = INTEGER: 27
    I see in my webinterface of the PDU 0.27 Ampere
    i have done following:
    1. Simple Change
    2. Custom multiplier: 0.100
    But my value is now: 0A
    i have tried with 1. Change per second, but is the same.
    Can anybody help me with this, why doen's i see ?
    • dimir
      Zabbix developer
      • Apr 2011
      • 1080
      For value conversion you can use preprocesing. E. g. Custom multiplier.
      • rvanderkooi
        • May 2019
        • 33
        1. Simple Change
        • rvanderkooi
          • May 2019
          • 33
          Sorry i have found it! i must set the number to float!
