Reag logfile from other host - error message
  • Seqway
    • Jan 2022
    • 9
    Dear all,
    i have succesfully running Zabbix server.
    It is connecting to several clients / agents and i made a new Item where i want to read some logfiles.
    Key: log[/var/log/pihole.log,error]
    Type: Zabbix agent (active)
    The strange thing is that the log file is succesfully red and it is shown in Zabbix but on server side i have the following messages in the log which i can't explain:
    zabbix_agentd.log:
    HTML Code:
    8936:20220105:092312.570 active check "log[/var/log/pihole.log,error]" is not supported: Cannot obtain information for file "/var/log/pihole.log": [2] No such file or directory
    8937:20220105:092313.589 active check "log[/var/log/pihole.log,error]" is not supported: Cannot obtain information for file "/var/log/pihole.log": [2] No such file or directory
    8936:20220105:092612.610 active check "log[/var/log/pihole.log,error]" is not supported: Cannot obtain information for file "/var/log/pihole.log": [2] No such file or directory
    8937:20220105:092613.633 active check "log[/var/log/pihole.log,error]" is not supported: Cannot obtain information for file "/var/log/pihole.log": [2] No such file or directory
    zabbix_server.log
    HTML Code:
    8961:20220105:092240.128 item "Zabbix:log[/var/log/pihole.log,error]" became supported
    8962:20220105:092312.821 item "Zabbix:log[/var/log/pihole.log,error]" became not supported: Cannot obtain information for file "/var/log/pihole.log": [2] No such file or directory
    8962:20220105:092339.833 item "Zabbix:log[/var/log/pihole.log,error]" became supported
    8962:20220105:092505.460 item "Zabbix:log[/var/log/pihole.log,error]" became not supported: Cannot obtain information for file "/var/log/pihole.log": [2] No such file or directory
    8964:20220105:092540.597 item "Zabbix:log[/var/log/pihole.log,error]" became supported
    8963:20220105:092547.633 item "Zabbix:log[/var/log/syslog,,,,,skip]" became not supported: Cannot open file "/var/log/syslog": [13] Permission denied
    8962:20220105:092552.654 item "Zabbix:log[/var/log/syslog,error]" became not supported: Cannot open file "/var/log/syslog": [13] Permission denied
    8962:20220105:092552.654 item "Zabbix:log[/var/log/pihole.log,error]" became not supported: Cannot obtain information for file "/var/log/pihole.log": [2] No such file or directory
    8962:20220105:092605.693 item "Zabbix:log[/var/log/syslog,,,,,skip]" became supported
    8962:20220105:092610.181 item "Zabbix:log[/var/log/syslog,error]" became supported
    8962:20220105:092640.489 item "Zabbix:log[/var/log/pihole.log,error]" became supported
    As i said, under History i see the pihole log file without any problems.
    What does this mean ?
    Just throwing things in the air here...
    Is that log being rotated/overwritten? What happens if you use logrt instead of log?
    Seems you have issues with syslog also, Permissions coming and going...
    Probably should mention hosts platform also, maybe someone has some ideas.
    • Seqway
      Seqway commented
      It was indeed a permission problem.
      I needed to check from where this message is coming and going and which Template it is related to.
      Also i needed to set the requestes file with CHOWN readable permissions to zabbix.
  • Seqway
    • Jan 2022
    • 9
    I Have to revise my statement.
    Again i have problems to read the syslog file. Here comes the message - where do i have to look to solve the problem:
    HTML Code:
    428:20220108:203254.206 item "Zabbix:log[/var/log/syslog]" became not supported: Cannot open file "/var/log/syslog": [13] Permission denied
    426:20220108:203255.105 item "Zabbix:log[/var/log/syslog]" became supported
    The file has read permissions for user.group = zabbix.root
    • Seqway
      • Jan 2022
      • 9
      Now i am totally confused !
      My logs from pihole Server are coming pretty fine under History. It is pihole.log and syslog from the system
      BUT on my Zabbix server i looked into the server.log and here i have every pollinh the same error messages. Please help whats wrong here ?
      Is it a timeout or why do i have these messages ? Once again the files are red fine in zabbix:
      HTML Code:
      428:20220110:122428.008 item "Zabbix:log[/var/log/pihole.log,,,,skip]" became not supported: Cannot obtain information for file "/var/log/pihole.log": [2] No such file or directory
      432:20220110:122442.353 item "Zabbix:log[/var/log/syslog,error,,500,skip]" became supported
      428:20220110:122515.870 item "Zabbix:log[/var/log/pihole.log,,,,skip]" became supported
      428:20220110:122542.266 item "Zabbix:log[/var/log/pihole.log,,,,skip]" became not supported: Cannot obtain information for file "/var/log/pihole.log": [2] No such file or directory
      435:20220110:122615.688 item "Zabbix:log[/var/log/pihole.log,,,,skip]" became supported
      428:20220110:122631.640 item "Zabbix:log[/var/log/syslog,error,,500,skip]" became not supported: Cannot open file "/var/log/syslog": [13] Permission denied
      433:20220110:122642.408 item "Zabbix:log[/var/log/syslog,error,,500,skip]" became supported
      432:20220110:122727.076 item "Zabbix:log[/var/log/pihole.log,,,,skip]" became not supported: Cannot obtain information for file "/var/log/pihole.log": [2] No such file or directory
      435:20220110:122802.717 item "Zabbix:log[/var/log/syslog,error,,500,skip]" became not supported: Cannot open file "/var/log/syslog": [13] Permission denied
      435:20220110:122815.728 item "Zabbix:log[/var/log/pihole.log,,,,skip]" became supported
      428:20220110:122828.803 item "Zabbix:log[/var/log/syslog,error,,500,skip]" became supported
      432:20220110:122831.697 item "Zabbix:log[/var/log/pihole.log,,,,skip]" became not supported: Cannot obtain information for file "/var/log/pihole.log": [2] No such file or directory
      433:20220110:122915.971 item "Zabbix:log[/var/log/pihole.log,,,,skip]" became supported
      428:20220110:122942.381 item "Zabbix:log[/var/log/pihole.log,,,,skip]" became not supported: Cannot obtain information for file "/var/log/pihole.log": [2] No such file or directory
      428:20220110:123016.521 item "Zabbix:log[/var/log/pihole.log,,,,skip]" became supported
      432:20220110:123027.599 item "Zabbix:log[/var/log/pihole.log,,,,skip]" became not supported: Cannot obtain information for file "/var/log/pihole.log": [2] No such file or directory
      435:20220110:123031.735 item "Zabbix:log[/var/log/syslog,error,,500,skip]" became not supported: Cannot open file "/var/log/syslog": [13] Permission denied
      433:20220110:123042.677 item "Zabbix:log[/var/log/syslog,error,,500,skip]" became supported
      428:20220110:123115.857 item "Zabbix:log[/var/log/pihole.log,,,,skip]" became supported
      435:20220110:123127.845 item "Zabbix:log[/var/log/pihole.log,,,,skip]" became not supported: Cannot obtain information for file "/var/log/pihole.log": [2] No such file or directory
      433:20220110:123203.119 item "Zabbix:log[/var/log/syslog,error,,500,skip]" became not supported: Cannot open file "/var/log/syslog": [13] Permission denied
      432:20220110:123216.163 item "Zabbix:log[/var/log/pihole.log,,,,skip]" became supported
      435:20220110:123229.234 item "Zabbix:log[/var/log/syslog,error,,500,skip]" became supported
      435:20220110:123232.250 item "Zabbix:log[/var/log/pihole.log,,,,skip]" became not supported: Cannot obtain information for file "/var/log/pihole.log": [2] No such file or directory
      428:20220110:123316.407 item "Zabbix:log[/var/log/pihole.log,,,,skip]" became supported
      428:20220110:123327.232 item "Zabbix:log[/var/log/pihole.log,,,,skip]" became not supported: Cannot obtain information for file "/var/log/pihole.log": [2] No such file or directory
      428:20220110:123416.621 item "Zabbix:log[/var/log/pihole.log,,,,skip]" became supported
      428:20220110:123431.975 item "Zabbix:log[/var/log/syslog,error,,500,skip]" became not supported: Cannot open file "/var/log/syslog": [13] Permission denied
      432:20220110:123442.751 item "Zabbix:log[/var/log/syslog,error,,500,skip]" became supported
      432:20220110:123528.121 item "Zabbix:log[/var/log/pihole.log,,,,skip]" became not supported: Cannot obtain information for file "/var/log/pihole.log": [2] No such file or directory
